MBP 2018 A1990, Voiceover works but no display after U9080 replaced
  • MicroSMD Lab
    • Sep 2018
    • 145
    • Trinidad and Tobago
    This Macbook came in for display replacement but had corrosion around U9080. I advised the customer but they did not want to pay for motherboard work... unfortunately at the time I was unaware of this common issue. Laptop returned after two weeks with no boot. PPBUS_G3H_SSD0_SND and PP2V5_NAND_SSD0 were shorted. When I removed U9800 the short was gone. I replaced U9080 and still no short.
    At first boot attempt I got 20V and heard the startup chime, no apple logo but saw the current draw exceeding 3A and I turned off power.
    I tried to boot without the battery and the current draw didn't exceed 2.5A so I assume the battery was charging as the reason for the > 3A draw.
    The laptop seems to boot but with no display, nothing external either. I see the "esc" light up on the touch bar, caps lock lights when I press it, I hear the voiceover come on when I press the power button 3 times and I'm able to navigate a bit by tapping the touchpad with 3 fingers and using the arrow buttons. I was able to shut down this way.
    I'm thinking that since the voiceover works then the NAND are good?
    I have not tried SMC or PRAM reset, safe mode yet. For now I just wanted to get an opinion about the NAND from the more experienced persons on the forum, I read on another thread that if the caps lock lights then the OS has booted. TIA
    Reason for reposting - I thought the title could be better, sorry if I made any violations. Admins please delete the previous thread I created for this.
  • Schluchti45
    MacBook Pro A2141 replaced battery not booting from battery not charging. Works with power suppy
    by Schluchti45
    i ask if someone has a hint for me. I have a A2141. The original battery died and i replaced it with a new one form Ifixit. After the replacement the MacBook Boots only with the power supply.
    Coconut Battery is recognize the battery but it is not charging. When i remove the power supply the MacBook is immediately dead.
    11-18-2024, 02:05 AM
  • Yehuda170
    ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
    by Yehuda170
    original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
    replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
    now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
    with original broken screen i can see in device manager touch screen in human interfaces
    but with the new screen it's not showing in device manager
    is it lenovo blocking it? is it driver missing?
    I²C is a headache
    07-14-2023, 01:29 AM
  • dragon3x
    by dragon3x
    power on.
    Here are some examples :
    switching supply area).
    than 6.3 V.)
    03-21-2025, 02:46 PM
  • CapLeaker
    Dell ATX PSU won’t start, but forcing it works fine?
    by CapLeaker
    Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
    Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
    10-28-2024, 06:59 PM
  • PITERPENY
    Macbook A2141 820-01700 no image
    by PITERPENY
    Hello! A little liquid got onto the 8500 connector, which led to a short circuit in the EDP_INT_AUX_N line in the U9850 . according to the scheme U9850 is identical to the MacBook A1707 820-00928 and I took it from this board and replaced it! (maybe they are not interchangeable? Tell me, otherwise the markings on them are different but according to the scheme they are identical)! I checked the display works on A1707. The cable was replaced and installed from A1707. (as I understand, on A2141 you can install a cable from A1707-A1990, but not vice versa). MacBook works with external display!...
    06-27-2024, 04:55 AM
