Hp 440 g4 charging
  • motanya
    • Nov 2021
    • 162
    • Kenya
    Hp 440 g4 charging
    Someone Help! I have an hp 440 g4 laptop, powers on with battery and adapter, works with either or both. If I connect the battery it does not show if charger is connected, if I remove the battery it shows charger is connected, I have changed charging ic and mosfets along the charging line but the behaviour is same, does anyone know how I can solve this?
  • mon2
    • Dec 2019
    • 14679
    Re: Hp 440 g4 charging
    Hi.
    1) be sure you are using a suitable power adapter for this laptop.
    2) attach the adapter & confirm the voltage to ground of ACDET pin #6 on the charger IC.
    • motanya
      • Nov 2021
      • 162
      • Kenya
      Originally posted by mon2
      Hi.
      Thank you for your response. I have used the correct power adapter that works fine with another laptop of the same model. The voltage reading is 2.7v. Is it okay?
      • mon2
        • Dec 2019
        • 14679
        ACDET is ok.
        What is the voltage to ground of the ACDRV pin? You can measure at pin #4 of the 2*DCin mosfets.
        This voltage must be ~25v to enable the mosfets.
        Often, the 2nd DCin mosfet gets damaged.
        • motanya
          • Nov 2021
          • 162
          • Kenya
          ACDET is ok.
          Interestingly enough the voltage is 25
          • mon2
            • Dec 2019
            • 14679
            With only the battery connected (no power adapter), what is the voltage to ground at the ACDRV pin?
            • motanya
              • Nov 2021
              • 162
              • Kenya
              with only the battery connected (no power adapter), what is the voltage to ground at the acdrv pin?
              0v
              • mon2
                • Dec 2019
                • 14679
                That is correct for this case - since only the battery is used to power the logic board.
                Remove all power. Meter in resistance mode.
                Check the resistance across the DCin mosfets to see if they are leaking.
                Source (1-2-3) & Drain (5-6-7-8)
                Source (1-2-3) & gate (4)
                Gate (4) & Drain (5-6-7-8)
                Post each measurement. If the resistance check is low, the mosfet is leaking and must be replaced.
                One meter probe to one pin to measure; other meter probe to other pin to measure. Also post the meter scale used for the check.
                • flat-earther
                  how to prevent a connected charger from draining battery when not charging?
                  by flat-earther
                  I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                  So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                  but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                  So the battery is backfeeding the charger and being drained.
                  How can I prevent...
                  08-07-2025, 01:04 PM
                • Thomasraud
                  Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                  by Thomasraud
                  i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                  QUOTED
                  -It works on charger (without battery connected-only charger)
                  -It works on battery (without charger connected-only battery)
                  -& it also works when plugged in battery & charger, but it's not charging the battery
                  //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                  and..
                  QUOTE
                  The IC cannot maintain the input current level
                  06-28-2022, 06:47 PM
                • master_haze86
                  820-01958-A no power sys led = white when charger is connected.
                  by master_haze86
                  Hi everyone.
                  First, let me preface by saying that I do not have much experience with diagnosing damages in motherboards other than visual inspection and checking simple short to ground faults.
                  But I do learn quickly, and really want to learn how to properly diagnose motherboard faults. If someone could have the patience to go over this board with me, it would be greatly appreciated.
                  A customer came into my shop with a A2179 MacBook with an 820-01958-A logic board. The reason for bringing the laptop in is that the laptop stopped turning on.
                  First thing...
                  02-15-2024, 05:30 PM
                • coasterghost
                  Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                  by coasterghost
                  For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                  Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                  Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                  System Hardware:
                  Processor: AMD Ryzen 7 PRO 5850U
                  Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                  09-08-2025, 10:46 PM
                • flat-earther
                  ASUS X54H laptop thinks it's always charging even with charger unplugged
                  by flat-earther
                  The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                  Windows also shows ''Plugged in'' when charger is not connected.
                  This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                  Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                  If I let battery run out and say it has 3% Windows will...
                  06-24-2025, 09:32 AM
