Surface Pro 5 No Power
  • crea2k
    • Oct 2016
    • 32
    I have a surface pro 5 in for repair. The charge port had liquid damage and some of the pins were corroded off so have replaced the charge port on it, but there is no power.
    I am getting 3.3v at the power button and have been following the following :
    POWER ON SEQUENCE (TBD)
    STEP
    Signal & Description
    1. Convert any raw power to +3P3VAS
    3. +3P3V_SAM / Generate SAM's power
    3. SAM_RESET# / Intialize SAM
    4. +VSYS / Declare system power ready
    5. PCH_DPWROK / Declare deep power good to PCH 6.
    6. SLP_SUS# / Request standby power
    Everything is good until I get to step 5 PCH_DPWROK which is zero volts.
    According to the schematic this is produced by u3600 / MK22FN512VDC12 which is on the back of the board. If I put the thermal camera over it its the only thing heating up on the board, but its only @ 25c so not exactly hot.
    It says on the schematic its the SAM, is that another term for the Super IO ?, if so is it replaceable ?.
  • ahmypc
    • Oct 2013
    • 80
    • Turkey
    Re: Surface Pro 5 No Power
    When I inserted the zero of the MK22FN512VDC12 chip, I could not get any results. It probably contains software. You need to find the one that was removed from a similar motherboard. You also need to make sure that all required voltages are present before the "PCH_DPWROK" signal.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
      03-31-2024, 02:12 PM
    • ipatch
      troubleshooting microsoft surface pro 4 no power no led charge light
      by ipatch
      hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
      10-05-2023, 11:59 AM
