Macbook A1466 No power
  • dclass-pro
    • Dec 2022
    • 157
    • Italy
    Re: Macbook A1466 No power
    Hi guys, I put this macbook aside and today I got an identical one! the problem is exactly the same, I've tried everything, I've also followed the link you recommended, reset smc and tried everything but the new macbook won't start, every 5/6sec it tries to start, I have 5v for a moment and then shuts down, looping endlessly. What do you advise me to do?
    • mon2
      • Dec 2019
      • 14086
      What is the voltage to ground of PM_BATLOW_L ?
      • dclass-pro
        • Dec 2022
        • 157
        • Italy
        PM_BATLOW_L is 3,325V fixed
        • mon2
          • Dec 2019
          • 14086
          Remove all power. Meter in diode mode.
          Red meter probe to ground.
          Black meter probe to point to test.
          Review each pin on J6100 against your logic board.
          https://logi.wiki/index.php/File:820...6100_FInal.jpg
          Post your measurements.
          • dclass-pro
            • Dec 2022
            • 157
            • Italy
            My J6100 have 32pin
            • mon2
              • Dec 2019
              • 14086
              What is the 820-**** number of your logic board?
              The connector of interest is the one that mates with the spi flash chip.
              • dclass-pro
                • Dec 2022
                • 157
                • Italy
                #27
                820-3437-b
                • mon2
                  • Dec 2019
                  • 14086
                  Is PLT_RESET_L pulsing?
                  • dclass-pro
                    • Dec 2022
                    • 157
                    • Italy
                    #29
                    no, is always 0v
                    • mon2
                      • Dec 2019
                      • 14086
                      Remove all power. Meter in DIODE mode.
                      Measure the DIODE reading of PLT_RESET_L.
                      What is the measurement ?
                      • dclass-pro
                        • Dec 2022
                        • 157
                        • Italy
                        #31
                        in diode mode 0.521 is not shorted
                        • mon2
                          • Dec 2019
                          • 14086
                          Review the voltage to ground of each of the highlighted pins on the SPI flash device @ U6100.
                          • dclass-pro
                            • Dec 2022
                            • 157
                            • Italy
                            #33
                            all 3,324V
                            • mon2
                              • Dec 2019
                              • 14086
                              Confirm the low resistance paths for each SPI flash interface pin between master and U6100 slave device.
                              • dclass-pro
                                • Dec 2022
                                • 157
                                • Italy
                                #35
                                I already checked all resistors and they are correct
                                • dclass-pro
                                  • Dec 2022
                                  • 157
                                  • Italy
                                  #36
                                  I also checked the lines and there is continuity
                                  • mon2
                                    • Dec 2019
                                    • 14086
                                    What is the voltage to ground of SMC_RESET_L ?
                                    • dclass-pro
                                      • Dec 2022
                                      • 157
                                      • Italy
                                      #38
                                      3.3V fixed
                                      • mon2
                                        • Dec 2019
                                        • 14086
                                        Check if you have U2071 onboard (SC-70 single AND gate).
                                        If yes, measure the voltage to ground of pin 1, 2, 4, 5.
                                        List each measurement.
                                        • dclass-pro
                                          • Dec 2022
                                          • 157
                                          • Italy
                                          #40
                                          not have U2071 onboard
