ACER 515-56G (LA-K092P) Not Power
  • tipoti
    • Oct 2015
    • 35
    • turkey
    There is no voltage on pin4 of the PQB3 mosfet. When I skip 1-2-3 with pin5, the device turns on. Of course it's not charging.
    pqb3 and pqb4 don't have any shorts
    can you help me thanks
  • mon2
    • 14748
    Re: ACER 515-56G (LA-K092P) Not Power
    Remove the series resistor on the gate pin. Do not lose it.
    Power up again. Measure the voltage to ground of the same series resistor but at the charger IC pin.
    What is the voltage?
    • tipoti
      • Oct 2015
      • 35
      • turkey
      There is no voltage on pin1-2 of the PRB4 resistor, the resistor is OK
      • mon2
        • 14748
        Remove PRB7 which is the ACDRV series resistor.
        Then check again the ACDRV voltage to ground on the charger IC. It should be ~25v if the charger IC is trying to enable the 2*DCin mosfets.
