820-00165 Charging Problem
  • Instafixx
    • Jul 2022
    • 374
    • India
    #41
    Re: 820-00165 Charging Problem
    Originally posted by mon2
    Interesting..so remove R7186 (C7185?) to remove this leg of the circuit as a fault?
    R7185 is required to keep Q7180 OFF during this testing. R7186 is switched ON / OFF by U7100.
    So WHAT TO REMOVE?
    • mon2
      • Dec 2019
      • 14667
      remove R7186 & C7185 to remove this leg of the circuit - see if this improves the detection of the power adapter.
      Do not lose these parts so they can be placed back if this does not resolve the fault.
      • reformatt
        • Feb 2020
        • 1501
        The FET is faulty usually, just replace it off a donor. I ordered 10 for stock recently as it's fairly common in the 2nd hand MAC's I buy.
        • piernov
          • Jan 2016
          • 4439
          • France
          #44
          https://logi.wiki/index.php/Magsafe_Sleep_Mode
          • mon2
            • Dec 2019
            • 14667
            Wow. Definitely missed this information. Very good to know. Thanks !!
            BTW - We got stung by an eBAY reseller who may still be active with 'authentic power adapters for Macbook'. We were excited and purchased a 10 pack. They feature the markings and logo like the original but are of course FAKE. They spark like mad if the pogo pins touch the metal clamshell of the macbook. Amazing how Apple allows them to sell the stuff..
            • reformatt
              • Feb 2020
              • 1501
              CMIZapper has a tester for genuine Magsafes. It'd be a handy tool, but it's a bit pricey for a tool that just tells you it's a knock off or not. Spark method seems a cheaper option Same goes for the Medusa. Would be justified if I was using it 5 times a day, but it doesn't take long to pop off U6100 and put in a programmer either.
              BTW, just noted he has a USB-C version of the Chipmunk tester. Will be grabbing one, as the USB-A one is just so damned useful. It's great for PC lappies too, not just MAC's.
              https://www.cmizapper.com/products/magsafe-tester.html
              https://www.cmizapper.com/products/usb-tester.html
              • mon2
                • Dec 2019
                • 14667
                We had a prototype working to extract the 1 wire interface vitals but was on a bench that was run over by a drunk driver. She / her insurance will be paying for our equipment for a long time. It is one of assorted widgets we are trying to cram inside a pending FPGA design. Single wire communication is quite well documented.
                • Instafixx
                  • Jul 2022
                  • 374
                  • India
                  #48
                  Thank you everyone for your help. Have changed the Mosfet. It seems to be charging okay now. Is there any way i can be double sure as i dont want the issue to rop randomly after 2-3 days and the customer coming back to me. Thanks in Advance.
                  • mon2
                    • Dec 2019
                    • 14667
                    Which mosfet was replaced?
                    • Instafixx
                      • Jul 2022
                      • 374
                      • India
                      #50
                      which mosfet was replaced?
                      q7180
                      • reformatt
                        • Feb 2020
                        • 1501
                        Had a customer machine come in today with this fault. Q7180 did not resolve it.
                        With board on the bench, everything buzzed out ok. With battery only connected it should be close to 0V on R7012 (Q7180 should allow no voltage back from the battery), however I was getting 2V here. I replaced Q7180 again thinking my replacement was bad, even took this off a known working board. So start to look at the biasing, and R7180 was completely corroded off the board. Pads were gone too. Amazing how something you miss seems so obvious once you see it.
                        Anyway, had to solder a 100K resistor to the test pad next to R7181 and run a jumper wire onto the other side (no other points to connect to on that side) to C7184. This fixed the fault (finally).
                        • Instafixx
                          • Jul 2022
                          • 374
                          • India
                          #52
                          Its been a while now and the machine didnt come back so i guess the Mosfet Q1780 did it for me!
                          But this info is very useful. Thank You!
                          Kudos to this Forum !
                          • reformatt
                            • Feb 2020
                            • 1501
                            So another machine not working with genuine chargers, but completely different cause.
                            The quick way to test if you have this problem is connect a battery to the board on the bench and check the voltage on R7012 (no Magsafe connected of course). Should be 0V. In this machine, it was about 6V or so. Q7180 was blameless, in fact I still had 6V with that off the board. Fault was a leaky D7005 allowing PPBUS_G3H back onto the PPDCIN_G3H_ISOL line.
                            • Instafixx
                              • Jul 2022
                              • 374
                              • India
                              #54
                              Interesting !! Thanks for the info.
                              • talel90
                                • Feb 2022
                                • 5
                                • France
                                #55
                                hi ,i had exactly same fault and i changed q7180 as said reformatt and piernov thank you
                                • brockauly
                                  Macbook M1 A2337 EMC 3598 weird battery charging problem
                                  by brockauly
                                  Hi guys,
                                  If I unplugged the battery and the charger, then plug the battery then the charger, it charges without problem.
                                  Then if I unplug the charger and plug it back, it won't charge anymore.
                                  In the first case, main voltage is regulated at ~12.5V and charges the battery.
                                  After unplugging the charger, main voltage drops to battery voltage at ~11.5V.
                                  After replugging the charger, main voltage stays at ~11.5V and won't go up to ~12.5V again.
                                  I found C520A (2.2µ after current sensor from USB-C source) completely burnt and removed it properly. I cleaned...
                                  02-05-2025, 10:51 AM
                                • drlarsen
                                  MacBook Air M1 A2337 battery/charging issue
                                  by drlarsen
                                  Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
                                  I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
                                  On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
                                  After some hours, the battery status did not improve. Restore via DFU did not help.
                                  I connected the power adapter to a Kill-a-Watt...
                                  07-17-2025, 02:35 PM
                                • rounin
                                  MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                  by rounin
                                  🛠 Original Issue
                                  ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                  04-19-2025, 01:18 AM
                                • ahmarzo
                                  Hp laptop charging problem
                                  by ahmarzo
                                  Have hp laptop motherboard part no opp 17 diner skl/kbl 15289-2 with charging problem.the laptop shows plug in charging but percentage doen not increases.the schematic or boardview is not available.
                                  Charging ic is bq737 with voltages on pin no
                                  1&2 -19v
                                  34&5 -0v
                                  6 -2.56 v
                                  7- 0v
                                  8&9 -3.15v
                                  10 -0v
                                  11 -0.18v
                                  12 & 13 -13v
                                  14&15 -0v
                                  16 -6v
                                  17;18&19 -13v
                                  20 - 19v
                                  Voltages on battery connector are
                                  1&2. -13v
                                  3&4 -3.14 v
                                  5&6 -0v
                                  8&9 are ground...
                                  03-20-2025, 05:13 AM
                                • Gueric
                                  Macbook Pro M1 (A2338) 820-02020 not charging.
                                  by Gueric
                                  I returned home from college. My MacBook battery was flat. Plugged it in. Nothing. Won’t boot. Waited for an hour. Nothing.
                                  When plugging the charger : 20v at 0.02 amps.
                                  pressing any key will make the « low battery » icon show up. Then switch to 5v and 420mA constant. Trackpad clicks, keyboard works.
                                  Decided to put the board into another M1 body with a charged battery, it’s booting perfect, still 5v and 420mA tho, and battery is not charging.
                                  I diode moded every pin of U5200 and they’re all fine. I know very little about Apple silicon machines...
                                  07-23-2025, 01:54 PM
