820-00165 Charging Problem
Re: 820-00165 Charging Problem
Wow. Definitely missed this information. Very good to know. Thanks !!https://logi.wiki/index.php/Magsafe_Sleep_Mode
The FET is faulty usually, just replace it off a donor. I ordered 10 for stock recently as it's fairly common in the 2nd hand MAC's I buy.
BTW - We got stung by an eBAY reseller who may still be active with 'authentic power adapters for Macbook'. We were excited and purchased a 10 pack. They feature the markings and logo like the original but are of course FAKE. They spark like mad if the pogo pins touch the metal clamshell of the macbook. Amazing how Apple allows them to sell the stuff..Comment
CMIZapper has a tester for genuine Magsafes. It'd be a handy tool, but it's a bit pricey for a tool that just tells you it's a knock off or not. Spark method seems a cheaper option
Same goes for the Medusa. Would be justified if I was using it 5 times a day, but it doesn't take long to pop off U6100 and put in a programmer either.
BTW, just noted he has a USB-C version of the Chipmunk tester. Will be grabbing one, as the USB-A one is just so damned useful. It's great for PC lappies too, not just MAC's.
https://www.cmizapper.com/products/magsafe-tester.html
https://www.cmizapper.com/products/usb-tester.htmlComment
We had a prototype working to extract the 1 wire interface vitals but was on a bench that was run over by a drunk driver. She / her insurance will be paying for our equipment for a long time. It is one of assorted widgets we are trying to cram inside a pending FPGA design. Single wire communication is quite well documented.Comment
Thank you everyone for your help. Have changed the Mosfet. It seems to be charging okay now. Is there any way i can be double sure as i dont want the issue to rop randomly after 2-3 days and the customer coming back to me. Thanks in Advance.Comment
Had a customer machine come in today with this fault. Q7180 did not resolve it.
With board on the bench, everything buzzed out ok. With battery only connected it should be close to 0V on R7012 (Q7180 should allow no voltage back from the battery), however I was getting 2V here. I replaced Q7180 again thinking my replacement was bad, even took this off a known working board. So start to look at the biasing, and R7180 was completely corroded off the board. Pads were gone too. Amazing how something you miss seems so obvious once you see it.
Anyway, had to solder a 100K resistor to the test pad next to R7181 and run a jumper wire onto the other side (no other points to connect to on that side) to C7184. This fixed the fault (finally).Comment
Its been a while now and the machine didnt come back so i guess the Mosfet Q1780 did it for me!Had a customer machine come in today with this fault. Q7180 did not resolve it.
But this info is very useful. Thank You!
Kudos to this Forum !Comment
So another machine not working with genuine chargers, but completely different cause.
The quick way to test if you have this problem is connect a battery to the board on the bench and check the voltage on R7012 (no Magsafe connected of course). Should be 0V. In this machine, it was about 6V or so. Q7180 was blameless, in fact I still had 6V with that off the board. Fault was a leaky D7005 allowing PPBUS_G3H back onto the PPDCIN_G3H_ISOL line.Comment
Interesting !! Thanks for the info.So another machine not working with genuine chargers, but completely different cause.
by brockaulyHi guys,
If I unplugged the battery and the charger, then plug the battery then the charger, it charges without problem.
Then if I unplug the charger and plug it back, it won't charge anymore.
In the first case, main voltage is regulated at ~12.5V and charges the battery.
After unplugging the charger, main voltage drops to battery voltage at ~11.5V.
After replugging the charger, main voltage stays at ~11.5V and won't go up to ~12.5V again.
I found C520A (2.2µ after current sensor from USB-C source) completely burnt and removed it properly. I cleaned... -
by drlarsenHello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
After some hours, the battery status did not improve. Restore via DFU did not help.
I connected the power adapter to a Kill-a-Watt... -
by rouninHi everyone,
🛠 Original Issue
⚠️ New Problem: One USB-C Port Only Works in One Orientation... -
by ahmarzoHave hp laptop motherboard part no opp 17 diner skl/kbl 15289-2 with charging problem.the laptop shows plug in charging but percentage doen not increases.the schematic or boardview is not available.
Charging ic is bq737 with voltages on pin no
1&2 -19v
34&5 -0v
6 -2.56 v
7- 0v
8&9 -3.15v
10 -0v
11 -0.18v
12 & 13 -13v
14&15 -0v
16 -6v
17;18&19 -13v
20 - 19v
Voltages on battery connector are
1&2. -13v
3&4 -3.14 v
5&6 -0v
8&9 are ground... -
by GuericI returned home from college. My MacBook battery was flat. Plugged it in. Nothing. Won’t boot. Waited for an hour. Nothing.
When plugging the charger : 20v at 0.02 amps.
pressing any key will make the « low battery » icon show up. Then switch to 5v and 420mA constant. Trackpad clicks, keyboard works.
Decided to put the board into another M1 body with a charged battery, it’s booting perfect, still 5v and 420mA tho, and battery is not charging.
I diode moded every pin of U5200 and they’re all fine. I know very little about Apple silicon machines... - Loading...
