820-01598 stuck at 20V 0.175A
  • Opunktvoll
    • Sep 2022
    • 22
    • Deutschland
    I´m working on a a2159 which doesn´t start anymore. It is stuck at 20v@0.175A. All_SYS_PWRGD is present. PM_PCH_SYS_PWROK is also present. CPU gets warm. I also get some fan spin, but nothing else happens.
    No waterdamage, board looks very clean.
    Not sure what to check next. Any suggestions?
  • mon2
    • 14664
    Re: 820-01598 stuck at 20V 0.175A
    Review this power on sequence for this logic board:
    https://drive.google.com/file/d/1oBr...SjpQfYbKq/view
    Attempt a DFU.
    • Opunktvoll
      • Sep 2022
      • 22
      • Deutschland
      DFU restore and revive didn´t change anything.
      I also checked the power on sequence diagram. PM_PCH_SYS_PWROK is the last entry. So if this signal is present, everything else during power on sequence should also be fine, right?
      My guess would be a CPU related problem, but I don´t know how to check if CPU is working fine
      • Opunktvoll
        • Sep 2022
        • 22
        • Deutschland
        I nailed it down to PPVDD_S0_CPU not being present. Measuring 4Ohm which looks good compared to other board.
        I also took a closer look at U7100 and U7210/7220 which are creating this rail:
        PP5V_COREVR_VCC: 5,1V
        PPVIN_S0_CPUVR_VIN: 12,63V
        CPU_VR_READY: 0V
        CPU_VR_EN_R: 1.8V
        CPUSA_FCCM: 2,5V for first 5 seconds, than going to 5V
        PPBUS_HS_CPU: 12,63V
        PP5V_G3S_CPUREG_MISC: 5,1V
        CPUCORE_FCCM: 2,5V for first 5 seconds, than going to 0V
        CPUCORE_PWM1: 2,5V
        CPUCORE_BOOT1: 4,79V
        PPVCCSA_S0_CPU is 1.05V and must be present before PPVDD_S0_CPU shows up, so that should be OK.
        I think U7210 needs both CPUCORE_FCCM AND CPUCORE_PWM to be present in order to create PPVDD_S0_CPU, right?
        Any Idea what´s the problem is and how to move on?
        • Opunktvoll
          • Sep 2022
          • 22
          • Deutschland
          There´s a mistake in my last post --> Must be PPVCC_S0_CPU instead of PPVDD_S0_CPU of course..
          Any Idea what to check next?
          • mon2
            • 14664
            Check the enable pin voltage to ground of PPVCC_S0_CPU regulator.
            • Opunktvoll
              • Sep 2022
              • 22
              • Deutschland
              CPU_VR_EN_R: 1.8V
              That´s the only enable pin I can find on U7100. Please correct me if it´s not the right one I´m looking at..
