Macbook A2159
  • Instafixx
    • Jul 2022
    • 374
    • India
    Macbook A2159
    Namaste,
    So i did a Macbook A2159 LCD only replacement with an after market screen from china. ( LCD Only, not the backlight or the entire assembly. Just the LCD).
    The Macbook boots with normal brightness then the brightness just dims. It is feels like 40% brightness at 100%.
    Why so?
    I think the supplier must have given a different version OEM display, maybe A1708 and this maybe a ALS issue which i could understand from the internet.
    is there anyway to bypass that or increase the brightness via some other app?
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: Macbook A2159
    Originally posted by Instafixx
    Namaste,
    Why so?
    Although it's recommended to return the LCD and acquire the original one ,but i feel you won't .
    If so , try some free programs like in this link and see if it can help ..
    https://en.softonic.com/downloads/screen-brightness
    • Instafixx
      • Jul 2022
      • 374
      • India
      Re: Macbook A2159
      Returning the screen is no longer an option as its already installed.
      Is there a way we can use terminal or some command to bypass this.
      Thanks for the softwares, but they dont work in this case.
      • mon2
        • Dec 2019
        • 14086
        Re: Macbook A2159
        Try a smc / pram reset.
        • jiroy
          • Jun 2016
          • 2416
          • Lebanon
          Re: Macbook A2159
          Try first resetting smc/pram , like mon2 recommended .. If it didn't work try this :
          Open system preferences -> displays -> color -> calibrate
          Make sure "Expert Mode" is checked.
          Click "Continue" over-and-over until you reach the "Select a target gamma" slider.
          Drag the slider to the left until it reaches the desired brightness.
          Click continue over-and-over until it asks you to name the color profile.
          • Instafixx
            • Jul 2022
            • 374
            • India
            Re: Macbook A2159
            Ho, I did an SMC reset and everything but nothing worked.
            Also could not find the settings you mentioned above, i am using MacOS Monterey.
            Could not find any expert mode.
            • mon2
              • Dec 2019
              • 14086
              Re: Macbook A2159
              Are these the same symptoms as your case?
              https://boards.rossmanngroup.com/thr...01598-a.60475/
              What are the voltage to ground for:
              I2C_ALS_SCL_R
              I2C_ALS_SDA_R
              • Instafixx
                • Jul 2022
                • 374
                • India
                Re: Macbook A2159
                I2C_ALS_SCL_R
                I2C_ALS_SDA_R
                Hi Mon2, i fear this is the exact case as mine. The supplier gave me a display for A1708 instead of A2159. I am wondering if we can change the board on the lcd flex cable with that of the A2159. It is soldered on and not a big task. I have asked the customer to bring back the old screen . Logically speaking it should work and the Macbook will recognize the screen as its original and should give proper brightness. I dont know ! Do you have any clue whether that ll work.
                Give me sometime i will post these above voltages.
                • Instafixx
                  • Jul 2022
                  • 374
                  • India
                  Re: Macbook A2159
                  I2C_ALS_SCL_R
                  I2C_ALS_SDA_R
                  Hi, its confirmed that the lcd is the wrong model. Checking those voltages will help?
                  • mon2
                    • Dec 2019
                    • 14086
                    Re: Macbook A2159
                    Personally was thinking of a hack. In the end, the display is an I2C based slave led driver from Texas Instruments.
                    Using a small I2C bus master, it should be possible to index this IC and change the intensity but such work will take time to develop. There are $0.10 usd micros from China that can do this with ease. Personally do not have the full details yet, but we could snoop the I2C traffic to learn the commands. Then change the intensity afterwards using our own circuit. If there is a value, can consider to develop it. It is a hack since the final solution will be a small pcb that mates with the I2C lines and us powered by this logic board. Just do not know how much time you have for this repair job.
                    Better if you can return the display to the vendor but if not, let me know.
                    • mon2
                      • Dec 2019
                      • 14086
                      Re: Macbook A2159
                      The ALS signals may be stuck. If stuck, the logic board may think the environment is requiring the display to be dim. Let me study the hack idea.
                      • Instafixx
                        • Jul 2022
                        • 374
                        • India
                        Re: Macbook A2159
                        Okay this sounds interesting, but i ll have to take the clients permission before intruding in the Motherboard. I will get back.
                        • Instafixx
                          • Jul 2022
                          • 374
                          • India
                          Re: Macbook A2159
                          So the issue was solved by replacing the Display. But on the Similar Topic, i have come across this vide on the internet and i am very fascinated by it.
                          https://www.facebook.com/watch/?v=408730854343533
                          Is this really possible to reprogram the LCD boards like this. This will really help Macbook repair shop all across to manage work with lesser inventory.
                          • tobeend
                            Bypass mdm macbook m2 ventura
                            by tobeend
                            1. RESET MACOS WITH IPSW
                            a. Power off MacBook, press and hold the power button to enter Recovery
                            b. Open Disk Utility, remove Macintosh HD
                            c. Reboot, connect to the network to Activate Mac.
                            d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                            d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                            e. Release the other keys, but keep holding the Power key for another 10 seconds
                            f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                            05-26-2023, 07:18 AM
                          • kenzo2
                            Please help me file Dump Nand Macbook Pro A2159 2 Nand 512GB
                            by kenzo2
                            I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
                            I need dump file MACBOOK PRO A2159
                            TSB4232(256)
                            TSB4229(256)
                            Thanks​
                            01-11-2025, 04:18 AM
                          • oxonater
                            Apple MacBook Pro A2141 16" IC BYPASS
                            by oxonater
                            Hi everyone hope all are well
                            I need a little expert advice on a issue I have and seeing as this forum is full of clever people I thought ask here as you never know.
                            I recently repaired a logic board 820-01700 which belongs to a 16" 2019 Macbook Pro, however I seem to be missing a component near the T2 Rom chip and is U4730.
                            The schematics say this chip is (M34128-FCS6_P/T) and it also says there is a bypass for it wondered if anyone come across either the IC or the bypass method.
                            I suppose it's worth noting googling the part package brings up various...
                            10-23-2024, 11:21 PM
                          • mferna14
                            Password removal on MacBook Pro A2159
                            by mferna14
                            Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...
                            05-13-2025, 04:16 PM
                          • harounHD
                            Macbook a1989 and a2338 icloud bypass
                            by harounHD
                            Is there a solution for Macbook a1989 and a2338 icloud bypass , i saw a video on youtube of someone using a bootable usb to unlock it
                            02-01-2025, 03:23 AM
