95 Jeep Wrangler computer w/bad caps
  • Reddogg
    • Aug 2010
    jeep quit on the road and had to have it towed. Computer went down. Priced a new one for $600 and a repaired one of $300. Opened it up and found leaking caps. replaced them for $6 and on the road again.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: 95 Jeep Wrangler computer w/bad caps
    That is the most awsome story!
    Did you take some pics?
    If not what where the original caps?
    Oh, and Welcome to Badcaps!
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      iirc one of topcat's (the forum's owner and admin) z cars had the same problem.
      95 sounds a bit old for the plague though... was it the original computer?
      sigpic
      (Insert witty quote here)
      • japlytic
        • Oct 2005
        • 2086
        Welcome, Reddogg!
        What was the manufacturer and series of electrolytic capacitors used as replacements?
        And did the vehicle computer ever get flodded?
          • 31294
          this is common with obd1 honda ecu's
          i think they are ncc caps.
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
