playstation 5 digital firmware dump
  • Fotik
    replied
    Hello, I need a dump for edm-030 cfi1200a. Thanks in advance.
  • Darky777
    replied
    Hello! I am new here, but I´m looking for a good dump of a CFI-1200a disc version to get rid of a 3 BOD console. Thanks in advance
  • Cobbes
    replied
    Originally posted by Shibz1996
    Please share Bios for CFI-121A. Tried one in the tread, showing invalid file error on PS5 NOR Modifier. Please help
    The name of the dump ends with .BIN but must be .bin for the PS5 NOR Modifier.
  • Cobbes
    replied
    Originally posted by Mousetohome
    Could someone help me out looking for a 1115B or this one to be fixed? I tried a 1116A no luck on it. Turned into a no power no beeps. I reflashed to this but still 3 beeps
    Thank you!
    I would try the attached dump.
  • Cobbes
    replied
    Originally posted by cicetto
    I've replaced wifi chip J20H100 but I've still no MAC Address in wifi and I can't update PS5
    I had a similar issue where the wifi MAC was not shown, but BT worked. After replacing the southbridge the wifi MAC was shown again.
  • cicetto
    replied
    I've flashed a CFI-1016A, now PS5 boot but it won't to update with error su-101217-2, I've seen it has no wifi MAC Address.
    What can I do?
  • Mousetohome
    replied
    Thank you!
  • Cobbes
    replied
    Originally posted by RotteNova383
    hello all. I've tried many different bios files for my 1015A disk edition, edm010. to no success. the most recent one i used another IC from a 1015A and used that NOR modifier to change serial..making sure i chose 1015A and DISK. console turns on and sometimes takes the disk and copies it, then it wont accept a disk at all... im really lost at this point, this seems relatively easy, but i must be missing something... I'd like to be able to use my original BIOs file and just fix whatever error is there, but i've no clue. any help would be GREATLY appreciated
    If your PS5 ist starting to the home menue and the disc drive is able to accept and copy PS5 discs, the data itself of the NOR is ok. You wouldn't get to this point if the NOR data is not ok.
    What is exactly the problem and what is the error message from the disc drive?
    If your disc drive is accepting disc but have trouble to read it and shows the error "Can't recognize...", the laser is mostly done.
  • RotteNova383
    replied
  • cicetto
    replied
    What can I do?
  • shvanmajd
    replied
    i have ps5 disk version cfi-1216a edm-031 61gg with 3 blod
  • Telscrt Telion
    replied
    To reconfirm your PS5 BIOS file, use the PS5 Nor Modifier to obtain details like the MAC address and serial number. Then, obtain another BIOS file, whether digital or on disc, and place it in the PS5 Nor Modifier. Take note of the data serial number and use a hex editor to modify the new BIOS file. It's preferable if the new BIOS file is the same model as your own.
    In the hex editor, use your main BIOS file as the source to edit the new BIOS file.
    Insert:ThumbnailSmallMediumLargeFullsizeRemove
    Sc​
    Then, use the PS5 Nor Modifier to verify if the serial number and MAC address have changed. Finally, choose the model and edition to generate.
  • ubreakifixer33
    replied
    Hello still looking for cfi-1015b edm-010 bios firmware digital edition. Can anyone help with that?
  • Shibz1996
    replied
  • Salaf
    replied
    Need help with, edm-040, cfi-2015.
    Getting:
    80801F12 Known Unknown 80801F12 (Kernel) - Report Findings - 1 sec blue light
    any leads would be appreciated with the fix.
    Ps5 draws: .2 - .3 and lowers to .07 Amps.
    During this stage,
    1. cxd90069gg ( southbridge ) heats up to 35c
    2. RT5126 heats up to 30c
    3. Da9081 heats up to 30c
    No shorts found on the main board.
    Any idea or leads ?
  • Salaf
    replied
    Hello Guys,
    Hope you had a wonderful day.
    I am in need for a nor dump for CFI-2015, Digital version. EDM-040. existing nor is damaged.
    Any help would be appreciated.
    Thank you.
  • Jay S
    replied
    Originally posted by Ale><
    for 1215a disk
    Thank you! hopefully this works for me.
  • Ale><
    replied
    for 1215a disk
  • Jay S
    replied
    Anyone have bios file for 1215a disk version? Have 3 beeps no power...
  • Dark Raven
    replied
    Still having problems with a PS5 "can't connect to server to verify licenses", tried restoring licences via system menu but it throws up an error code two thirds through (error code CE-105628-2​) anyone have any ideas to a solution? tried resetting console, reinstalling systems software via USB etc, the console will install and play games via disk with no problems, it's only games downloaded from PSN that throws up the error & won't start the games, the console updates fine.
