Turbo Start QPET 16V/25A racing charger repair
  • CapLeaker
    Leaking Member
    • 8290
    Another weird charger. Didn't even know that there is a 16V AGM battery. I guess that's what racing guys use and it's quite the complicated thing looking at the inside of it. Never have seen a charger like that. No schematic or anything.
    Complaint: It doesn't charge the battery.
    Anyone knows what a HIS235 or HS10235 is? Can't find anything about it.
    The unit turns on red PWR Led is on and I've got like 40V laying on the secondary of the main transformer, but get nothing at the cable clamps. Not sure, but I think it may want to see an actual battery on the charging terminals before it turns on. I also think it is an AGM battery charger and it does have a timer circuit.
  • R_J
    • 9580
    Re: Turbo Start QPET 16V/25A racing charger repair
    I would thiink it needs to see a battery connected before it outputs any voltage.
    • CapLeaker
      Leaking Member
      • 8290
      I measured around for shorts / opens. Well... those HIS235's are bad. I took both of them out and they have a failed in a strange way. The center pin isn't connected to the tab. Both outer pins are shorted together. There is no connection from center pin or tab to any of the outer pins.
      I think the AC form the secondary side of the transformer needs to get rectified. The HIS I think is standing for SCR, but what 235 or 236 means in an actual rating, I have no idea. A SCR in a TO247 package should have a pin out of Anode, Cathode and Gate. That means in my case anode and cathode are wide open, but the anode is shorted to the gate. Makes sense, why the charger doesn't work.
      Better question is now with what do I replace these HIS235's with?
      • CapLeaker
        Leaking Member
        • 8290
        HIS235 translates to SCR 200V 35A. It should be Cathode, Anode, Gate. Both SCR’s are shorted cathode to gate (pin 1 to 3). The tab and anode (middle pin 2) are wide open. The case style is a TOP3. Now I wonder if more is wrong with the gate drive or not.
        • CapLeaker
          Leaking Member
          • 8290
          Ordered some Little Fuse S4035JTP SCR 400V 35A TO218X with isolated tabs. That should do the trick. Didn't find anything wrong with the components on the Gate.
          • redwire
            • 3912
            It looks like a typical battery charger using phase control. The SCR's gate is driven by the H11 opto-couplers U4, U5. There's a current-transformer so it must do CV/CC control.
            The only scenario where the SCRs could fail I think is a reverse polarity connection to the battery.
            You'd have to sketch a schematic to figure out the calibration trimpots.
            • CapLeaker
              Leaking Member
              • 8290
              Yes, this charger isn’t that dumb. It’s also got a timer IC in there. The parts in the gate drive are good, just both SCR’s are shorted cathode to gate leaving the anode wide open. There is a trimpot for trip, limit and current, each. Each SCR does a half cycle of the sine wave.
              • CapLeaker
                Leaking Member
                • 8290
                Turns out the SCR's are actually O.k. when tested with my bench PSU. The DMM and another component tester didn't have enough oomph to trigger the gate.
                Problem was in the wiring. A chaffed cable to case GND!
                Unit works fine now!
                • motormayhem
                  Lenovo T460 Only Charges on One Charger
                  by motormayhem
                  Laptop Question
                  I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                  A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                  05-12-2023, 01:46 PM
                • flat-earther
                  how to prevent a connected charger from draining battery when not charging?
                  by flat-earther
                  I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                  So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                  but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                  So the battery is backfeeding the charger and being drained.
                  How can I prevent...
                  08-07-2025, 01:04 PM
                • flat-earther
                  ASUS X54H laptop thinks it's always charging even with charger unplugged
                  by flat-earther
                  The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                  Windows also shows ''Plugged in'' when charger is not connected.
                  This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                  Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                  If I let battery run out and say it has 3% Windows will...
                  06-24-2025, 09:32 AM
                • Johndill
                  Dell Inspiron 7567 LA-D993P odd charger issue
                  by Johndill
                  Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                  There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                  I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                  Here are the tested scenarios:
                  1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                  2. With the laptop off, plug in charger (LED says on) & the front charging...
                  11-16-2022, 10:55 PM
                  ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                  Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                  The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                  for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                  Narrow VDC applications where the system power source is
                  either the battery pack or the regulated output of the charger.
                  This makes the max voltage to the system equal to the max
                  battery voltage instead of the max adapter voltage. Operating
                  at lower system voltage can improve...
                  11-05-2024, 04:43 PM
