Electrical heater controler
  • tomalamix
    • Nov 2020
    • 32
    • Portugal
    Re: Electrical heater controler
    Originally posted by R_J
    B10S must be the numbers on the bridge rectifier BR3, this bridge contains four (4) diodes.
    How much voltage should be in the output since the input is 220V ? By reading the datasheet I can't understand the correct value.
    • R_J
      • 9553
      You will need to measure the voltage into the bridge rectifier It will not be 220vac as it is dropped through two resistors.
      Measure the AC voltage across the two pins marked ~~ Then measure the DC voltage across the pins marked - +
      • CapLeaker
        Leaking Member
        • 8213
        If you had 2.4VDC on the output of BR3, I think that is not right. Check those SMD resistors between the 310v cap.
        • R_J
          • 9553
          I missed that 2.4v, Yes that is too low, There seems to be a zener diode next to C18, what are the numbers on it? Also what is the value of C18? try replacing C18
          • tomalamix
            • Nov 2020
            • 32
            • Portugal
            Ok, measured in the ~~ side, there is 5.8V AC, both resistors are inside the expected value.
            On the +- side there is 3.8V DC
            I've solved the grounding wire that wasn't properly connected but the problem as returned to stage 1, the light fades away, so does the LCD display, but now its worst, the unit doesn't come up after a few seconds stays apparently Off without responding to any inputs.
            • tomalamix
              • Nov 2020
              • 32
              • Portugal
              #26
              I've replaced C18, problem remains. Ther diode next to C18 is a EIC41 218D5 , can't find anything on the web about it, testing values are Uf=712mV C=599pF.
              I'm starting to give up about this, I can't see anything obvious failing...
              • R_J
                • 9553
                With 5.8vac into the bridge you should get about 8vdc out, so it could be that the bridge is bad.
                Just to be sure I see two diodes around C18 This is the one I meant Z???
                Is the diode connected across C18?
                • tomalamix
                  • Nov 2020
                  • 32
                  • Portugal
                  #28
                  Hy!
                  How do you know that the output value is 8 VDC? I cant get that from the datasheet. Sorry to ask.
                  thank you!
                  • tomalamix
                    • Nov 2020
                    • 32
                    • Portugal
                    #29
                    Hy,
                    Did you had the opportunity to check my message? thanks!
                    • tomalamix
                      • Nov 2020
                      • 32
                      • Portugal
                      #30
                      back to the project now...
                      The diode is connected to C18 and is a EIC65 218D5. Can't find anything on the web about it.
                      What about the bridge output, how to be sure about how much voltage should be in the Output? By reading the datasheet i cant be sure.
                      thanks
                      • sew333
                        Apartment to buy with coal heating. Any sense to buy electrical heater and new pc?
                        by sew333
                        Hi guys. I have an question. Overall i am currently selling my house ( apartment with 1 room ) to buy some cheaper with 1 room too, and save cash for new pc in autumn 2024.
                        So i choosed some cheaper apartment in smaller city,but there is coal heating. I dont wanna heat for coal.
                        So i m thinking to buy electrical heater. And my question . Is this any sense to buy electrical heater when i will be using new pc with rtx 5090 and new intel ( when will be released ) ultra + Psu Seasonic 1600W?
                        I expect that i will pay more for bills. But i wanna know this. Will using electrical...
                        06-14-2024, 07:30 AM
                      • edugimeno
                        Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                        by edugimeno
                        Hi!!
                        Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                        I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                        At a certain point, moving stuff around, I put all wires back in place and...
                        03-24-2024, 02:31 PM
                      • CapLeaker
                        AcuRite 5 in 1 temperature sensor replacement repair
                        by CapLeaker
                        Got a new victim:
                        AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
                        A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
                        B: stuck at some temperature and maybe updating once in 12 hrs or so.
                        Easy solution is to go to AcuRite website and purchase the sensor. Right?...
                        04-15-2025, 01:32 PM
                        Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                        by sam_sam_sam
                        I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                        I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                        12-16-2023, 08:39 PM
                        Surface Mount Fuses Fundamentals Datasheet
                        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                        10-07-2024, 06:07 AM
