Nintendo Switch draws 470mA one side on 5v only and boots ...
  • badcapped
    • Aug 2014
    • 6
    Hello
    I have done some Nintendo Switch Consoles, but this one is getting to me.
    I am a few years from 'retirement' and things are getting hectic - just to get on with daily repairs I do to get to the 'retiring' time!
    I am no expert on consoles but here it is and I am not much on forums, although I would love to - I have not time, with family commitments too - everybody always asking for something!
    It came with its charging port 'snapped' from its welded anchor plate.
    I believe customer had previous problems and wiggled connector for a long time before it stopped charging - I wish he came earlier!
    The connector itself was holding onto 8 side B [top] pads only, and both anchors on the front disappeared, then found one inside!
    What I have done is:
    1. First attempted fixing pads - all 15-16 of them!
    It was working, but I noticed one in particular was naughty and I re-done it. Same problem.
    2. This time I approached the preferred method of wiring it, but not having enough knowledge and I not having a working one at the time, I browsed internet to find connecting points.
    Anyway, found info [hopefully correct] and wired it.
    Then replaced M92 + PI13 + BQ chips and now it does charge at 0.470A only on 5v - nothing drawn from 15v both sides. (a classic I believe but ...)
    [B]3.[.B] I have taken diode arrays off and replaced M92 again + PI3 too
    No change
    4. I charged original battery and my new battery living it for quit a few hours.
    5. I also taken 'all' Voltages and diode mode measurements twice [from internet pages I found] and checked for short 'everywhere' 7 times or more in the long run !!!
    I wish I had a working oe to compare it with. Initially I had the cap under PI3 shorted and replaced it only because one side looked bad, but measuring cap it was not short and also replaced PI3 - this is another weird one, as after taken the cap off and re-measured there was NO short - I am thinking maybe one anchor bit reached it.
    I did measure M92 switching ports - so it does detect them and I also used Freeze spray on both sides and changing connection to port to see what was happening.
    Nothing particular and I could only see the 2x Mosfets in parallel under M92 (not the top one) getting 'slightly' warmer when switched - denoting they are switching too - also measured voltage - as far as I understand it.
    Bear in mind it does boot normally - always, with on-off or by connecting the 'detected' side of the cable
    I had it for a while now and no idea what to do next - I am stuck and customer waiting, although I believe he must have another one. I am my brain full of Nintendo confusion now.
    My soldering of chips are fine and I believe chips are OK - believe me and I do not understand why it does not charge on other side.
    One thing I do not know, can this type of behaviour 'also' have anything to do with the CPU - just asking.
    Anybody ever had 'this' particular behaviour and can really help?
    I am getting tired of it now.
    Thanks in advance
    M
    PS sorry if I do not participate much ...
  • Baspotv
    Nintendo Gamecube missing component DOL-CPU(P) - 01 (Side A)
    by Baspotv
    So today I was checking on a GC board that I got from a friend and he told me the GC would get an error and doesnt want to read games after a couple of hours gaming on it. So I suspected it to be some bad solderconnection or an capacitor, when checking the solder connections of various components one of them was so loose that it flew off. I think the component right next to it is the same. The board says it's DA15 and I've never heard of that designation. The Text on the component says A1, and this also doesnt help me out. Maybe one of you guys knows what part that is so I can order it instead...
    10-30-2024, 01:11 PM
  • flibidy
    Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
    by flibidy
    I have here a Magnum IA.100 which belongs to my parents.
    The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
    Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
    What Ive done........
    01-01-2025, 01:26 PM
  • bouny56
    Lenovo E15 Nm-c421 usb-c work only in one side
    by bouny56
    ​Hello
    Laptop E15 I5 10gen
    Mb nm-c421
    I have a problem with the usb-c power dc.
    The motherboard start only in one side of the usb-c
    Replace the usb-c port 2 times same problem
    With the usb-c meter, one side 20v ok, other side the usb-c meter don't come on
    Try to test the pin with the Mechanic Tail insertion tester and every pin are ok ?
    Can the pd controler be the fault ? Or something else maybe ?
    Thx
    02-11-2025, 03:15 AM
  • fab13
    Nintendo Switch lite shuts down after nintendo log and replaced M96T36o
    by fab13
    Hello everyone
    After checking the defective USB-C port and close to a short circuit on the M96T36 chip (8ohm) I have changed both components.
    I specify that there is no other short circuit or heating component(Vu thermal camera)
    First, the problem arises: Error 2101-0001 after the start-up screen ("Nintendo" logo), poor soldering.
    Secondly, I install a new M96T36 and the problem I have is a brief display of the "Nintendo" logo (no short circuit, no sure charge chip, no sure charge port, no sure charge management chip percentage)....
    08-23-2023, 10:54 AM
  • raider988
    Nintendo 64 PSU - Secondary side dead
    by raider988
    Hey guys. I have this PSU with the secondary side completely dead and I need some help in troubleshooting and I couldn't find a schematic for it. I'm still a beginner in electronics so please bear with me.
    There is no visible damage to any component, the PSU is reasonably clean with no burnt smeel whatsoever. The secondary side seems completely dead, I couldn't find any voltage anywhere, not even at the transformer's terminals. It seems as if the transformer is not doing its job, maybe because it's bad or because it's not told to switch on .
    Here's what I checked...
    06-07-2019, 01:35 AM
