Fanatec Wheel Base PCB Eyelet Replacement?
  • mgrharry
    • Sep 2016
    • 211
    • usa
    Working on a Fanatec wheel base assembly with a damaged USB port. It has a USB B female USB port (like a printer). One of the traces underneath the USB port as torn, and the PCB eyelet is damaged. The torn trace itself is not to big a deal to fix, but the eyelet is another matter. It's the eyelet for one of the smaller USB data pins, is it possible to find a replacement eyelet somewhere? Where can I order something like that? And what tool would I need to crimp it in place?
    Thanks.
  • mgrharry
    • Sep 2016
    • 211
    • usa
    Re: Fanatec Wheel Base PCB Eyelet Replacement?
    Mouser maybe for eyelet, I guess I can measure size of original eyelet with caliper. Although it seems they only have brass eyelets, not copper.
    https://www.mouser.com/c/electromech...q=pcb%20eyelet
    There's also https://www.circuitmedic.com/index.html
    Prices seem high but perhaps a better selection than mouser.
    Any recommendations on eyelet setting tool for this small size?
      • 30956
      the board doesnt have islets, it's through-hole plating.
      if you can see where the pin connects then run a jumpwire, if not because it runs inside the board then you have some work to do
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8056
        jb weld it. just make sure all the connections are made properly.
          • 30956
          so jb is non-conductive??
          i thought it was "metal loaded epoxy" ??
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8056
            JB weld makes all kinds of epoxy including non conductive. I use it to fill in holes in boards all the time. I just find this JB weld is better than LePage. Preference I guess.
            • R_J
              • Jun 2012
              • 9534
              I don't think he is trying to fill a hole, the hole which had a feed-thru is where the usb pin is located, he just needs to connect a thin wire between the usb pin and where the trace went.
                • Jul 2011
                • 6030
                Which JB weld do you use on circuit boards I have need to fill holes before
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8056
                  Not sure on top of my head but it's something called like Clearweld. It dries clear like any other clear epoxy.
                    • Jul 2011
                    • 6030
                    Thanks for the information
                    • mgrharry
                      • Sep 2016
                      • 211
                      • usa
                      Eyelets are tiny, 1mm hole width and 1.5mm flange head. Only place that seemed to have it was CircuitMedic. The refill kit here should do the trick:
                      https://www.circuitmedic.com/products/201-3140.html
                      • petehall347
                        • Jan 2015
                        • 4425
                        i normally put a strand of wire through the hole and call it done .. has to carry enough current though .
                          • Jul 2011
                          • 6030
                          Or another option is to take wrapping wire and rap around the compost pin and make a pad where is none left I have done this yes it takes some patience and a little bit of trial and error for you to get it right
                          • astroboypaul
                            Surface Book 2 Performance Base dead
                            by astroboypaul
                            I'm working on a Surface Book 2 performance base (M1032224-004 on white sticker) and would love for some help troubleshooting or where to look next.
                            The tablet when not connected to the base seems to work fine, but:
                            • When tablet is off and connected to the base, it won't turn on.
                            • Connecting tablet that is already on to base there is a windows device detected tone (not sure what device), but tablet remains in tablet mode, keyboard/trackpad don't work, and windows continues to report only 1 battery.
                            • Charger white light turns on when connected to the base, but base battery and tablet
                            04-25-2025, 12:40 AM
                            HP EliteBook 840 G5 + Samsonite Base Boost Notebook 800 Specification for Upgrade or Repair
                            This specification for the HP EliteBook 840 G5 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + Samsonite Base Boost boardview and 840 G5 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                            09-06-2024, 09:00 AM
                            HP EliteBook 1050 G1 + Samsonite Base Boost Notebook 1000 Specification for Upgrade or Repair
                            This specification for the HP EliteBook 1050 G1 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Samsonite Base Boost boardview and 1050 G1 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                            HP EliteBook x360 1030 G3 + Samsonite Base Boost Hybrid (2-in-1) Specification for Upgrade or Repair
                            This specification for the HP EliteBook x360 1030 G3 + Samsonite Base Boost Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G3 + Samsonite Base Boost boardview and 1030 G3 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
