Motor control board repair
  • R_J
    • Jun 2012
    • 9535
    Re: Motor control board repair
    Originally posted by cyclones
    It looks like the -15V goes back to SR3 and the voltage regulator that doesn't get warm, AVR2. From looking at the trace lines and from the meter, it seems like the AVR2 is in parallel. SR3 has a + and - and two middle pins that go to the AC input, so it seems like a rectifier bridge, but I don't know what the SR3 designation could mean. Any ideas?
    Are you getting a/c voltage to SR3? It is likely a bridge rectifier, why it is labeled SR3, who knows.
    If you are not getting any a/c to the bridge, check the resistance of the traces and the power supply winding that supplies that circuit.
    What is the part number on SR3?
    • cyclones
      • 69
      Is it going to be safe to power up the board with 120VAC? That's about 10% higher than the 107V at the machine. I assume any voltage regulators should be able to handle that but just wanted to check first since I've not dealt with something that is expecting 107V.
        • Jul 2011
        • 6037
        If this machine has a step down transformer that supply’s power to this board look and see if it says 110 volt or not because if does do you know if your facility has a hot leg if it does then you might have the transformer on the wrong set of legs because if the step down transformer says 110 to 120 volts output
        Because I has this happen to me one time and when I switch the legs to a certain way I got the correct voltage however do not change the machine main power supply legs unless you do NOT have any other motors on this machine because your rotation might be wrong
        • R_J
          • Jun 2012
          • 9535
          It should be ok, but you could also just check the resistance like I said. The transformer winding should connect directly to the ~~ connections on the bridge rectifier.
          • cyclones
            • 69
            Yes, it does. I measured half an ohm (0.5 ohms) resistance on the traces. The letters and numbers on the apparent BR are LBA 63.
            • R_J
              • Jun 2012
              • 9535
              I suspect you have the -15 volts, It was only missing because the main transformer was not being used.
              • cyclones
                • 69
                #27
                I tried it in the machine with everything connected and the -15V was missing.
                • cyclones
                  • 69
                  #28
                  I just connected my DC power supply to the middle pins of SR3 (where the AC is supposed to go) and supplied 20 volts and the -15V rail comes up.
                  • R_J
                    • Jun 2012
                    • 9535
                    That proves the bridge rectifier and the rest of the -15v circuit is ok. The fault is then with either the transformer not supplying the a/c to the bridge or there is a break (or small fuse) between the transformer and the bridge rectifier.
                    I hope the transformer was NOT connected when you applied the 20 volts to the bridge? if it was that may have opened the winding on the transformer as the winding would be a very low resistance to the 20vdc.
                    • cyclones
                      • 69
                      #30
                      Well, I found the problem causing no -15V. It's the connector. It's not making good contact, but I'm sure I accidentally bent that pin when I was originally trying to measure transformer output voltages. So I'll have to either fix that or replace the connector. I've seen this type before so I assume I can find one.
                      So now I guess I power it up on 120V with attention to that connector and see what I get.
                        • Jul 2011
                        • 6037
                        Let us know if you were able to fix this board issue or not
                        • m1ch43lzm
                          by m1ch43lzm
                          05-12-2025, 08:37 PM
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • Yanleb
                          LG 60PK550 Logic Control Board EBR63450301
                          by Yanleb
                          Hi all, I just want to share the repair of my 60PK550-UA TV set.
                          The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                          But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                          All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                          C57: 3.30V
                          C61:...
                          07-20-2023, 12:38 AM
                        • Joe24
                          Maytag Whirlpool Kenmore clothes dryer data bus
                          by Joe24
                          Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
                          Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
                          I've been over the board looking for...
                          01-13-2025, 06:50 PM
                        • howardc64
                          by howardc64
                          07-24-2025, 05:17 PM
