xbox 360 smd cap fault
    i installed JR Programmer v2 to jasper motherboard i think on correct points i connected power cable only no run! on jrunner Im getting the error: Flash Config: 0x00000000 Can not Continue now i see burning smoke on 2 smd capacitors on point C3B8 and C1D7 i don't know why motherboard demaged before motherboard working very well how to fix that ? pls help me
    Re: xbox 360 smd cap fault
    Just remove the two capacitors. Ceramics go short a lot of times for no reason.
    A working TV? How boring!
      Before install rgh chip console works well after rgh no run i lost red light on rgh chip ind blocked my adapter to red light, i remove smd cap on point C1D7 and again console run i desolder all wires but if replace new capacitor again burn and again no works this cap block one mosfet on motherboard if again remove this cap and solder rgh wires console again run well but give me error E76 sometime E75 when press eject buton i have hell reloaded cpu key and dvd key with out this cap console work but now error i see on internet this E76 is network isc chip if isc is dead is reason to burn this smd cap ? this is very starnge before isc chip no have this error E76 rgh console run to xbox live without this smd cap if ics demage voltage is high on this capacitor C3B8 and C1D7 i buy this ICS 1893BFLF on ebay i will try to reflow this chip sry for my bad english
        if install new capacitor i have short to ground on one mosfet and smd caps i don't know what is wrong with this xbox
          i need help for capacitor
          Xbox adapter capacitor 100uf 400v have 92uf is good cap or bad ? because my xbox won't turn on no any power no red ring nothing, adapter on yellow light
          when press power i have only beep sound motherboar is trinity 16mb
