Re: Fixing a laboratory waterbath
Hey guys,
Took a 24h break from this. Now I m back at it.
I powered on the waterbath, the display lit up for a second then turned off. Moving it around did not make it turn back on. After some measurements, I found that the fuse on the power supply PCB blew. Below is the PCB. The culprit is the fuse above the "15v" text in green. I removed it to double-check, and indeed there is no continuity.
Do you know why it might have been fine yesterday and blew as soon as I turned on the machine today?
Is this an indicator that something in the circuit is pulling too much current?
Can I bypass the fuse? I guessing that's risky.
Hey guys,
