Generic in-dash navigation system AAOGP300194/365125
  • japlytic
    • Oct 2005
    • 2086
    This unit runs on Windows Embedded CE 6.0 Core, and I am looking for pinouts of each connector.
    • 31090
    Re: Generic in-dash navigation system AAOGP300194/365125
    did you search the "mast" number, or power it up to see if there is a splash-screen with a makers name?
    • R_J
      • 9558
      It looks similar to this: https://www.myturbodiesel.com/d2/100...10-swap-vw.htm Could be from a VW
      • japlytic
        • Oct 2005
        • 2086
        This was enough info for me to power up this unit - the boot screen is "Opal" and the home screen has the Volkswagen logo; the navigation software is NaviOne with the OS being PRIMA-v1.53 (the unit has a bad SD card for navigation).
        But I still wonder why the unit had generic branding on the labels in the first place (possibly an aftermarket replacement?).
          • 21196
          https://www.ebay.com.au/itm/HOLDEN-C...p2047675.l2557
          • Pescado99
            • Dec 2022
            Hi, further to this thread, I picked up (literally from the side of the road) a similar double DIN in dash DVD player with GPS - which looks unused. However, the rear plugs are different to the other '365125' unit in this thread. Does anyone recognise this particular unit? I'd love to power it up if I can get the pin-outs :-) Thanks in advance brains trust.
            • 007ROCKY
              • May 2023
              Can you post up your leads and plugs as I have similar
              • 007ROCKY
                • May 2023
                Obviously these units go under the name of Opal, does anyone know of any links to the manufacturer for more info?
                • Noayme
                  • Apr 2024
                  • 3
                  I know this is old stuff but I have the wires here ( can send pics ) if you need them as I am trying to fix it from my daughter's car, or waste it goes.
                  • Noayme
                    • Apr 2024
                    • 3
                    also have the manual
                    • BleedCap
                      OLD Socket 478 custom bracket + NEW generic cooler
                      by BleedCap
                      I already posted this on vogons.
                      Its a 3d printed custom bracket for socket 478.
                      I used this AM4 bracket as a base design.
                      Its to be use with cheap generic clip based cpu cooler.
                      Reason for doing this is:
                      - Its hard to get/find a good copper base cooler. Even if you find one, the price is ....
                      - New generic cooler is cheaper and can use bigger fan (less noise)
                      I tested the bracket with cheap chinese horizontal cooler + fan taken from CM hyper 212 evo.
                      The processor that I was using is P4 2.4Ghz prescott....
                      11-05-2023, 08:09 PM
                    • G0RIT
                      Reebok one GT40s treadmill lift motor runs at switch on
                      by G0RIT
                      Good evening I am working on a Reebok oneGT40s treadmill. It had a flashing display which the replacement of D3 rectified. However the lift motor now runs when the mains is turned on and does not stop. If I then select start so the tread motor runs and disconnect the up lead to the lift motor it stops. If I then reconnect the lead the lift motor works as it should with the controls. It will continue to work correctly until the mains is turned off and on again, or the safety device is removed and replaced. It then runs again and only by disconnecting and reconnecting the up lead will it operate...
                      06-23-2022, 05:57 PM
                    • AllElectronicsRepairs
                      Pinouts for CG2313QIR-00, CG3215QIR-00 and 88E6020-NNC2
                      by AllElectronicsRepairs
                      Would somebody PLEASE have pinout for any of these 3 chips: Sigma Designs (Coppergate) CG2313QIR-00 (QFN-64) and CG3215QIR-00 (QFN-128), as well as Marvell 88E6020-NNC2 (QFN-64)? I tried everywhere I could think of on the internet without success. You can buy them alright, although not at any of the major distributors - mostly eBay, but I can't find any datasheets or at least pinouts. How one is supposed to design anything without such a basic information like chip pinout? Not even mentioning any more detailed properties... These integrated circuits are used in EOP (Ethernet Over Power) and POE...
                      12-09-2024, 11:12 PM
                    • tyl85
                      Imac A1418 late 2013 21.5" fan runs at max speed
                      by tyl85
                      Hi, i have this iMac issue
                      I've checked temperature by using macfans with no results
                      techtool pro shows me AMBIENT AIR TEMP FAULT
                      i'm going crazy, the mac runs very slowly
                      where i can find this sensor on motherboard?
                      thanks in advance
                      12-03-2024, 01:09 AM
                    • maleksa
                      Roland Fantom XR. Help with LCD screen pinouts
                      by maleksa
                      The LCD screen on my Roland Fantom XR rack synthesizer has gone blank. I managed to get the schematics for the connection to the LCD.
                      The standard LCD has D0 to D7 pinouts (in addition to the normal VDD, VSS, CS, RES, RW, EN etc).
                      Can someone help me to identify what V1 to VR is for? Also how does VR work?
                      Any help is truly much appreciated....
                      06-03-2024, 08:27 PM
