Pinouts for CG2313QIR-00, CG3215QIR-00 and 88E6020-NNC2
  • AllElectronicsRepairs
    • Feb 2020
    • 21
    Would somebody PLEASE have pinout for any of these 3 chips: Sigma Designs (Coppergate) CG2313QIR-00 (QFN-64) and CG3215QIR-00 (QFN-128), as well as Marvell 88E6020-NNC2 (QFN-64)? I tried everywhere I could think of on the internet without success. You can buy them alright, although not at any of the major distributors - mostly eBay, but I can't find any datasheets or at least pinouts. How one is supposed to design anything without such a basic information like chip pinout? Not even mentioning any more detailed properties... These integrated circuits are used in EOP (Ethernet Over Power) and POE (Power Over Ethernet) architecture. Please help me if you can!
    I am actually trying to reverse engineer a circuit board for a bunch of identical devices I am trying to repair. The fault is very illusive, so I decided to draw a circuit diagram in order to understand the flow of the signals and find the fault. It's Ethernet Over Power (2 wires) system with transmitter and receiver connected by 2 wires. The power is successfully transferred between them, but data not. It stops somewhere on the transmitter side and doesn't even reach the connection wires. Also, I tried datasheets.com but I can't sign up.
    Kind regards, Jerry.
    • Feb 2020
    • 21
    Sorry, my mistake! it should be CG3213QIR-00 not CG2313QIR-00
    • pickledegg
      Dell Inspiron 7501 / Vostro 7500 (2020) - eDP connector pinout/panel compatibility question
      by pickledegg
      Hello. I have an Inspiron 7501 here, it's the same as a Vostro 7500 in some markets (no clue). I was looking to replace the LCD, the panels included with these models are terrible.
      I have the schematic and it is a 4 lane eDP port on the board but the pinout seems quite weird, my question is if anyone recognises this weird pinout and knows of any other Dell models that may use it or even any compatible panel models. I have the 40-40pin cable that was used for the models with touch but do not need touch capability, was just looking for a better quality screen and higher refresh to actually...
      10-02-2024, 04:54 PM
    • valvashon
      Repair Success! Middle Atlantic UPS2200R-IP
      by valvashon
      Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
      Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
      02-06-2024, 12:54 PM
    • Dannyx
      Wire twisting tool for small wires - ideas ?
      by Dannyx
      Good day folks. Recently, I started doing more and more alarm system installs which involve dealing with a ton of small wires which are part of 4 to 12 core alarm cable. To make my installs as clean and neat as possible, I twist together the individual wires whenever possible to make braids like in the picture. It takes a lot of time and wears on my fingers really quickly, to the point where I actually developed a blister on my index finger from all the twisting. This got me thinking if there's a tool designed to braid small wires like this. I know there is something for twisting together solid...
      08-23-2020, 06:29 AM
    • maleksa
      Korg Kross2 Service Manual and LCD pinout
      by maleksa
      The LCD on my Korg KROSS2 keyboard is cracked and needs to be replaced.
      However, the cost of a replacement LCD is almost the same as the price of a second hand Korg KROSS!
      Does anyone have a copy of Korg KROSS2 Service Manual? I want to see the PINOUT for the LCD connection. Perhaps I can find a compatible LCD screen and not have to spend a fortune on an original replacement LCD.
      From what I can gather, the LCD screen is a COG with serial interface (SPI). Is there any way I can ascertain (perhaps with the use of a multimeter or oscilloscope) the PINOUT by...
      10-11-2024, 05:54 AM
    • lti
      Sony MDR-IF245R transmitter LED replacement
      by lti
      I'm looking at the transmitter from these wireless headphones because the range is too short. One of the LEDs failed many years ago (nine years ago - I found pictures that I took then) and was simply bypassed to make them work again, but it seems like the range has been degrading since then. They're near-IR LEDs (I can see them dimly lit red, so they aren't the standard 940nm), and I haven't been able to find the actual wavelength. Does anyone here happen to know what replacement LEDs I should use? Maybe I can adjust the transmitter was well while I'm in there, or there's another fault. I should...
      06-28-2024, 01:47 PM
