seagate ST4000DM000 FIRMWARE
  • ismaelstepheno
    • Jun 2020
    • 234
    • UE
    Please someone can help me to fix the firmware of this seagate 4000gb
    SN:S3000GAG
    ST4000DM000
    PN:1F2168-568
    FW:CC54
    DATE :14202
    I THINK THE FIRMWARE IS CORRUPTED WHEN I CONNECT THE HARD DISK IT RECOGNIZED JUST 3,86GB
    I DOWNLOAD A FIRMWARE FROM GOOGLE CC54 BUT ITS LONG IF SOMEONE PLEASE CAN FIX IT WITH HxD THIS THE BACKUP AND THE FIRMWARE I DOWNLOADED
    • 22182
    Re: seagate ST4000DM000 FIRMWARE
    If you need the files from the drive its best to send it to a pro.
    https://forum.hddguru.com/viewtopic.php?f=28&t=38267
      • 31291
      are you trying to format it as FAT32 using a windows machine???
      • ismaelstepheno
        • Jun 2020
        • 234
        • UE
        thank you for your help is to recover data , in windows 10 machine i bought a new pcb and change the bios chip from the original to the new pcb but still the same the pcb have no short all is ok, It is only recognized in disk management 3.86gb
          • 31291
          try on a different computer,
          or try with a Linux livedisk
          what does the bios say about the drive?
          • ismaelstepheno
            • Jun 2020
            • 234
            • UE
            yes i tried en different computer . its an external hard disk
              • Jul 2011
              • 6070
              Try putting it in a computer as a backup and see if it reports the right value that way because I have had some external hard drive controllers sometimes have issues
              • zklgfs
                Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                by zklgfs
                I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                08-11-2025, 02:14 PM
              • TheUser
                Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                by TheUser
                Hello to everyone ,
                This is my first post here, and i would like to share with you a small story in case you can help me.
                Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                02-10-2024, 02:07 PM
              • gurj1979
                Ubiquiti firmware help. US-8-150W POE
                by gurj1979
                Hi guys.
                I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                Got New chip and writes good.
                THE PROBLEM...
                It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                Does anyone have a Good Firmware I can have?...
                07-22-2024, 05:13 PM
              • Slapito
                Request for EC firmware for MSI Vector GP66 12UHSO (MS-15441 ver 1.0)
                by Slapito
                I'm currently repairing an MSI Vector GP66 12UHSO laptop with a motherboard reference MS-15441 ver 1.0. The EC chip (ENE KB9548QF2) on the board appears to be damaged and needs to be reprogrammed.
                Can someone please send me the firmware (EC/Embedded Controller) or indicate where I can download the correct EC firmware version corresponding to this motherboard model?
                I already have access to the BIOS downloads on the MSI support page, but need specifically the EC binary or its equivalent firmware image.
                I already downloaded the BIOS update file from msi official...
                10-09-2025, 02:00 AM
                HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                09-12-2024, 02:00 PM
