Gardena R38li lawnrobot mainboard power issue
  • CapLeaker
    Leaking Member
    • 8327
    Re: Gardena R38li lawnrobot mainboard power issue
    I am glad to hear that the repair was a success!
      • Jul 2011
      • 6065
      Another product that did not end up in a landfill good job getting it to work again
      • Nairolf
        Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
        by Nairolf
        I have a Samsung DM32D display.
        When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
        Here’s what I have tried so far:
        1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
        2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
        3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
        From these tests, I suspect the problem might be on the mainboard. Could anyone...
        08-24-2025, 03:47 AM
      • harshana
        DA0ZPVMBAD0 rev d Mainboard - blank screen issue
        by harshana
        I have the DA0ZPVMBAD0 rev d logic board and it doesn't boot up. I see all the voltages are okay. So I suspect the issue is bios.
        When I power on with fn+ esc the blue light start blinking on mainboard.
        I guess its a good sign. As all the voltages are okay and also charging indicates orange light when battery connected, I think it confirm that the EC bios is okay. So I ignored the ec and flashed main bios with 32mb bin file provided in the link below. But the condition is same.
        https://www.badcaps.net/forum/troubl...and-electronic...
        08-16-2025, 02:16 PM
      • alltvrepairs
        Samsung HG49EE690 Hospitality TV reboot issue Mainboard BN94-11086A
        by alltvrepairs
        I have 3 of these TVs for repair with same problem of going to standby after around 10minutes and start again continuously. I have tried a new SPI 25Q40 but fault remains. Am suspecting a CPU problem as it gets a bit hotter than I expect.
        This seems to be a common problem in these models. I am 100% sure it is a mainboard issue as I have fitted a spare from a normal TV from a UE40K5607 and stays on (diplay inverted but I managed to rotate in SM using a different display).
        Any help appreciated!...
        03-14-2024, 03:39 AM
      • dbuergi
        PS5 Dualsense controller stick drift a mainboard issue?
        by dbuergi
        I got a controller where the left stick was moving left all the time (-1.00 at calibration tool). Even after changing to hall effect sticks it stayed the same and reset and all others things didn't help.
        I removed the stick again and even without it calibration tool shows a movement to the left. Anybody knows where the fault can come from? Maybe any bridges or damaged SMD components?
        05-02-2025, 05:00 PM
      • YOUCEF4787
        Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
        by YOUCEF4787
        I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
        Initial Problem:
        The laptop was completely dead, no signs of life, no power LED.
        Action Taken:
        I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
        Current Situation & The Main Issue:
        The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
        09-21-2025, 12:19 PM
