I have a LED 80 watt yard light with a sold state circuit board bad capacitors
    • Jul 2011
    • 6059
    This light got to where it would turn on when it felt like it ( photo cell controller board issue )
    It has one 47uf@50 volts and one 10uf@50 volts double rating on the ESR reading ( non brand name capacitors )
    Now every time I cover the photo cell and remove cover it turns on and turns off like it should
    I will try to take a picture of the little board before I put it back together
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8299
    Re: I have a LED 80 watt yard light with a sold state circuit board bad capacitors
    I used to run through bags of these photo cells. These days I am way too busy to bother with them.
      • Jul 2011
      • 6059
      At first I thought it might have been the photo cell but when I saw this circuit and how it was setup I just replaced the capacitors first and see what happened next when it now respond to light and darkness I knew that what the problem was
        • Jul 2011
        • 6059
        Update it has been running for last 2 days and nights with out any problems
          • Jul 2011
          • 6059
          I have torcher tested yard light for a week now and it has been running flawlessly so this has been a successful repair
          I been using it with the photo in the dark then every once in awhile I shine a light on the photocell and shuts right off then remove the light from the photocell and turn right back on
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • repair-it
            Engineering help - how does the charging circuit on this board work?
            by repair-it
            This board attaches to 2 12v batteries in tandum (Black/Red squares). There is a 24v power supply that attaches at the 2 pin molex connector (circled in red). I need help to determine which components run the charging circuit in an effort to determine a point of failure. There are multiple via's, making it difficult to trace the circuit. Nothing appears to be shorted but I wasn't able to fully test as I do not have 2 12v batteries available. My assumption is that the micro controller (red question mark) determines when to turn the charging circuit on & off. I'm pretty sure a regulator and...
            08-31-2024, 12:32 PM
          • Crrose
            How to test circuit board battery connection.RS-4i sequential stimulator
            by Crrose
            Not sure where to post this but I have an RS-4i sequential stimulator that runs off rechargeable batteries and also has a VL2330 coin cell battery that retains the memory. If that battery doesn't hold charge or connection is bad then the unit will power on and say to recharge. Once it is charged it indicates it is charged but when you turn unit on it powers off saying to charge batteries. I replaced that coin cell battery and now it won't even indicate batteries need to be charged. I have tested the battery pack and it is fully charged at 6V but the coin cell only shows 2.97V which is a brand...
            03-21-2023, 03:55 PM
