Potters Wheel - Faulty Power Switch, can anyone identify?
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    This is the controller from a Potters wheel, for throwing pots (like the film Ghost)
    It is controlled by a foot pedal which sets the speed. There is an on off switch, a reverse direction switch and a circuit breaker.
    The owner said he turned it on, there was a flash (but no bang or smoke) and now it is dead
    The circuit breaker checks OK (and had not tripped), and I can't see any shorts on the PCB around the power FETs/Transistors or whatever they are. However the push button power switch appears to be open circuit between all three pins. At first I could get it to latch in the on position after a few attempts but now I removed it, it will not latch on
    Does anyone know what make/type of switch this is? I tried to get a clear photo of the markings
    Also it does not make sense to me - there are three terminals on the switch but it couldn't be a SPDT - it would not make sense - see the dickyCAD wiring diagram in the attached pics. But because it is completely open circuit I can't figure out what it is supposed to be. On the markings it says 1/2HP 120V 1HP 240V. Is this some sort of special motor switch? This is not my area of expertise.
    I could email them I guess - the website seems to be active.
    Follow me on YouTube
    Learn Electronics Repair
  • wotsupnow
    • Feb 2016
    Re: Potters Wheel - Faulty Power Switch, can anyone identify?
    I reckon the two blacks are the switch and the white is for a neon inside the switch to light when it's on.
    Pete
      • 31094
      diameter of the switch or mounting hole is needed
      and strip it down - see if the 3rd pin is negative for a neon
      i presume it's running at 230v
        So they use switch with 110VAC (as printed on the body of the switch) NEON indicator light instead of proper 220V indicator.
        The switch is made by ARCOLECTRIC as shown on the body, you should be able to see the P/N.
        I use lots of ARCOLECTRIC high in-rush switches in lots of products.
        https://cdn.badcaps-static.com/pdfs/...7f565bd84d.pdf
        • dicky96
          Sun Seeker
          • Mar 2017
          • 1825
          • Spain
          Neon in the switch makes sense.
          What I am not so sure of, is why the big electrolytic is 150V when this unit runs on 220V. It says so on the sticker at the side of the controller (which I did take in the pics) and 220V is what we have here anyway.
          • petehall347
            • Jan 2015
            • 4428
            • United Kingdom
            has it ever worked for the owner ?
              Are they using the step-down transformer with the unit?
              https://www.lagunaclay.com/potterswheels
              • dicky96
                Sun Seeker
                • Mar 2017
                • 1825
                • Spain
                Yes it was working. I don't think they need use a step down transformer - on the side of the controller box it says
                GT 400
                240VAC 50/60Hz 2.2A
                • dicky96
                  Sun Seeker
                  • Mar 2017
                  • 1825
                  • Spain
                  Forgot to add a pic
                    • 31094
                    can you see a plate on the motor with it's details?
                    • dicky96
                      Sun Seeker
                      • Mar 2017
                      • 1825
                      • Spain
                      I don't have the motor - just the controller. I spoke to the owner, he used it for several years and doesn't have a transformer.
                      He says the on/off switch normally lights up so it does have a neon
                      I decided to dismantle the switch and it looks like what has happened is the legs of the neon have managed to short somehow, the resistor in there has a hole blown in it and the neon bulb is rattling around inside the switch
                      There are also two small springs rattling around in the bottom of the switch body
                      So for now I fitted a small plastic plate and a different sort of switch to see if it works
                        GT 400
                        240VAC 50/60Hz 2.2A
                        Well, I would check the DCV on that 150VDC cap to see what it shows.
                        • petehall347
                          • Jan 2015
                          • 4428
                          • United Kingdom
                          wondering why it has a 110v switch ...
                            https://www.badcaps.net/forum/attach...7&d=1598522909
                            It looks like they do make GT-400/800 240V version but they did not change the switch for 240V indicator.
                            https://fliphtml5.com/dnki/paxk/basic
                            • petehall347
                              • Jan 2015
                              • 4428
                              • United Kingdom
                              poor practice but most likely ok anyway ..voltage rating is likely about flashover ...might well be rated for more current in theory .but theory is unknown to me here .
                                • Jul 2011
                                • 6047
                                This looks like a 90 volt DC motor controller some of these DC motor controller are crappy made and do not control the motor very well at low speed
                                ****Your input voltage might be different but the adjustment are going to be very similar if not the same ***** it looks like this version has only the low speed adjustment which is easier only one speed adjustment
                                One note if you want the motor to not turning when the front control is turned to minimum make sure that there is no voltage to the motor if not and you leave it at minimum you might over time overheat the motor because it stalled state
                                They are very hard to adjust to make the motor respond to very slow speed
                                Now some of these controllers work better than other brands
                                Now some have a maximum and a minimum speed control for the motor this type of controller is even hard to adjust the minimum and maximum speed you have adjust the minimum first then the maximum second then check the minimum speed again if you have to make another adjustment then you have to check the maximum speed again because it might have changed
                                You have the main speed control on the front of the controller what I am referring to is board adjustment for the front control response
                                Please be aware of this issue before making any adjustment to these controllers ( one note only make very small turn on the pot control one degree at a time make sure you know which speed you are adjusting ) now if you feel very frog-e then you can do this while you are running the motor but if you do it this way please be very careful where you are putting the screwdriver while you have power to it doing this way is easier but not as safe with the power ON first step is turn the front speed control at minimum and set it to the speed you want then turn the front control to maximum speed and adjust the board maximum speed control if it has one ( one note if you turn the maximum pot to far you can burn up the motor ) need to check the voltage to the motor do not adjust more voltage than the motor is rated for)
                                These motor controller are found on some track torch and on some industrial saws for the feed vise
                                I have had to adjust these controllers before and they can drive you a little nuts or you might want to pull your hair out if you have any only because you might think you have it adjusted correctly but the next time you go to use it the minimum speed adjustment is not what you want to have but it was when you used it the last time
                                I hope this helps you
                                • dicky96
                                  Sun Seeker
                                  • Mar 2017
                                  • 1825
                                  • Spain
                                  Thanks guys
                                  Sam got it mostly correct - the motor is 90V
                                  I didn't get around to checking the voltage on that big electrolytic as I had already given it back to the customer to test.
                                  Having replaced the switch for a standard rocker switch (250V no neon indicator) it now works. I didn't need to adjust anything obviously.
                                    • 31094
                                    you need to put a different switch on it before someone with wet hands gets shocked or killed - rockers are terrible with water
                                    • dicky96
                                      Sun Seeker
                                      • Mar 2017
                                      • 1825
                                      • Spain
                                      Ahhhh didn't think of that!
                                        • 31094
                                        yes, wet clay hands and such
                                        the original switch had deep contacts
                                          Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                                          This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 05:30 AM
                                        • OnRepair1
                                          Help Identify 1 componente From a Thrustmaster wheel
                                          by OnRepair1
                                          Hi i have been looking at a wheel from thrustmaster T300 there is a componente that its burn out and its impossible to read the code on in
                                          The componente is the Q17 (Next to the fuse FB34) it seems that its starts with a 2 but nothing else i can see.
                                          Does someone know or have the schematics of it?
                                          04-19-2025, 11:57 AM
                                        • Natob82
                                          Micro Momentary Push Switch?
                                          by Natob82
                                          Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                                          12-21-2022, 05:22 AM
                                        • grimacelord
                                          NEC TurboExpress On/Off Power Switch Replacement Help
                                          by grimacelord
                                          I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                                          I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                                          I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                                          11-09-2023, 09:49 AM
                                        • SluggerB
                                          Help making a switch work the opposite way with a relay
                                          by SluggerB
                                          I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                                          I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                                          It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                                          02-07-2025, 07:57 PM
