Help identify a resistor
  • mikey5791
    • 521
    • Malaysia
    Recently i kind of busted my Proskit
    MT-1210 digital multimeter by putting my probe on a hot ground instead of cold ground while measuring a diode on secondary power rail.
    My issue is I am trying to test and replace any damaged resistor. There is one resistor on the left bottom part of the colour green,silver,white,white,black. Can anyone advise on what is the value and how do i test it on a dmm. Appreciate all the kind suggestions.
  • mikey5791
    • 521
    • Malaysia
    Re: Help identify a resistor
    Attached a picture of the dmm.
    • R_J
      • 9628
      Which resistor R?? the colors you mentioned would be 0.99Ω 0.5% I see part of a resistor stuck to the greese on the bottom left of your picture.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8715
        I think the OP meant the one near D1 on the upper left, probably because the picture is now rotated CW by 90 degrees from the description?
        Either way the it would be tough if it actually discolored due to heat. That picture has a lot of weird things in it...
        • mikey5791
          • 521
          • Malaysia
          Identified the resistor as 0.99 ohm and tested it as working part. Eventually found out a damaged resistor at R27 (600ohm).
          Now i can go ahead with the repair.
          Thanks for all the input.
          • gica69
            Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
            by gica69
            I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
            Resistor shows orange range silver gold and green lines.
            Thanks in adv...
            07-21-2025, 09:49 PM
          • jinu_j
            by jinu_j
            Hi
            05-03-2025, 10:51 PM
          • mikey5791
            Need help to replace burned resistor in 350w atx psu
            by mikey5791
            Hi to all forum members,
            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
            12-26-2024, 04:55 AM
          • MidnightRoller
            Can a resistor lose resistance after hot air?
            by MidnightRoller
            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
            02-02-2022, 11:46 PM
          • sikocan
            Identify resistor R802 PS4 Pro PSU
            by sikocan
            Hi team, can you help identify value of this resistor. From a PS4 Pro. PCB board model: N300A004L. Location of resistor is R802 as pictured....
            11-01-2022, 07:33 PM
