Fi-Shock SS-725 Testing
  • paceuser
    • Apr 2020
    • 14
    I am trying to figure out what is wrong with a Fi-Shock SS-725 Electric Fence Energizer. It does not seem to have enough output. I get two screwdrivers (one on the positive and one on the negative) and about 1/16 away from each other I can see some electricity (spark) flowing from one screwdriver to another. But it looks like its not enough. I am trying to see if I can get my hands on an analog KV Meter. Could I test with a Digital Meter? Here are the input/output specs:
    FI-SHOCK
    SS-725
    Input
    AC Powered, 5 Acres. Plugs into a standard
    110-120 V outlet. Has a continuous AC
    current output.
    Output
    800 V
    +/- 20%
    open circuit
    voltage
    Thank You.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: Fi-Shock SS-725 Testing
    The pulse from the fence energizer is too fast for most meters. It will destroy cheap meters that do not have proper protection. I think what you are saying / experiencing is to be normal for this fence energizer, since it is just a lil tiny thing build more for like rodents and not big live stock. It only does like 800V, while the big ones do 6 to 8kV easy.
    If you do find that it used to work / spark better when it was new, replace the capacitor inside.
    • FrancescoV
      Onkyo HT-R390 no sound output, video output ok
      by FrancescoV
      Good morning everyone,
      I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
      The firmware reported is the following:
      M:1.00/11107BLP
      D:?.??/????????
      O:1.00/11107AL
      The DSP firmware given the question marks seems corrupt.
      On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
      05-11-2025, 02:59 AM
    • bauto601
      KDM 480W PSU upgrade succes! (opinions?)
      by bauto601
      Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
      A "nice" YoungYear unit? - Badcaps
      The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
      12-26-2023, 03:05 PM
      Corsair CX750M [Model 75-002019] - burned output toroid inductor
      by momaka
      Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
      So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
      09-19-2021, 08:44 PM
    • CoppellTVRepair
      Troubleshooting PFC with SPC1012T not raising output
      by CoppellTVRepair
      It has been a long while since I posted here to ask anything....hope you can help.
      I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
      I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
      03-09-2025, 10:38 PM
    • flibidy
      Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
      by flibidy
      I have here a Magnum IA.100 which belongs to my parents.
      The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
      Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
      What Ive done........
      01-01-2025, 01:26 PM
