PS4 3 Beeps and BLOD
  • alty
    • Jun 2019
    Hi all
    Hoping someone can steer me in the right direction.
    I have a CUH-1202B phat PS4
    When pressing the power button it beeps to turn on,within a second or 2 it beeps again 3 times just like the overheating 3 beeps not the 3 eject beeps,It then sits indefinitely with a pulsing blue light(BLOD)
    I obviously cannot enter safe mode.
    What I have done
    Replaced the PSU and still the same
    No obvious damaged components
    Checked all fuses and are ok
    Reballed the APU and still the same
    Reflowed the SB and still the same
    I've never encountered a BLOD with 3 beeps on startup
    Hoping someone has had and repaired this issue that can enlighten me
    TIA
  • retrorepair2
    HP Z820 Workstation 4 beeps (sometimes)
    by retrorepair2
    I've got an issue with my Z820 that I'm having trouble working out the root cause of.
    More often than not it'll turn onand fans will blast for a moment before stopping and I'll get 4 beeps that will repeat forever (at least the power light will keep flashing).
    What I can't understand is sometimes it'll just work and I can use it all day but other times it'll boot then reboot then reboot and 4 beeps for the rest of the day. Sometimes it'll work fine from cold for hours, sometimes it'll do the 4 beeps from cold.
    Another oddity is the fans. Before the 4 beeps...
    09-24-2025, 08:05 AM
  • ktmmotocross
    Old hp compaq nc6320 weird beeps after low bios battery
    by ktmmotocross
    Hello.
    Have this old hp compaq nc6320 that came with one long and one short beep + backlight on. bios battery have only 0.5V. I remove it, but now it start beep some weird way. I think it is bios /one long + two short beeps+ baklight on/, but when i flash new bios from hp, no beeps and no backlight.
    i attach record of beeps...
    04-27-2025, 12:48 AM
  • Wompatti-
    Ps5 edm-020 3sec BLOD
    by Wompatti-
    I have a ps5 with blue light flashing about three seconds when I press the power button and then it turns of. Second press, only beeb but nothing else. Third press, 3sec blod etc...
    BUT the weird part is if I unplug the power cord and put it back, the console will start without pressing the power button and give that 3sec blod.
    UART shows error code 80800024 and nothing else. There are no cracks on the apu. No shorts on the board that I can find. All standby rails are present and all power on rail will show up for that 3second period. I've tested with two different psu and reflashed...
    08-19-2025, 11:44 AM
  • CDNBrewer
    Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
    by CDNBrewer
    Hello Everyone,
    I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
    Symptoms:
    • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
    • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
    • I swapped the Left and Right surround
    08-05-2025, 09:29 PM
  • KappaDev
    HP ENVY x360 15m-dr0011dx 8 Beeps
    by KappaDev
    I have an HP Envy x360 15m-dr laptop which sometimes beeps 8 times on startup and sometimes gets no beeps at all (both with no picture).
    Power button light comes on, fans spin and stop after a few seconds, then screen stays black with no picture. If the machine decides to beep 8 times, it shuts off immediately after. According to what I could find, 8 beeps was corrupted BIOS.
    Made backup of original BIOS (attached). Attempted to flash BIOS with extracted bin file from HP BIOS update. Screen showed "Updating boot block", rebooted and immediately back to 8 beeps and...
    01-09-2023, 11:18 AM
