Xbox One Issue
+ More Options
Posts
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Xbox One Issue
    system error e200 0000007A 00000000 Wont start any help guys ?
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Xbox One Issue
    hard reset the xbox one hold down power button for 10 seconds
    http://gotb.co.uk/fix-xbox-one-error-code-e200/
    • Unspun01
      • Jun 2011
      • 349
      Re: Xbox One Issue
      Sounds like your XBOX One was turned off or lost power in the middle of an update. Software issue (not hardware issue) and likely fixable by yourself with a little time.
      Try vinceroger69's advice above, or install factory reset. You will need to visit XBOX.com support page and download some of the update files and you will need 4GB or 8GB USB memory stick for the files as they are quite large.
      • LEEDASH
        • Dec 2012
        • 481
        • Bedfordshire
        Re: Xbox One Issue
        Just switches on once then spins once them Goes off
        • gshark1
          Gaming laptop rtx 2070: Disappearing GPU after BSOD, Only using integrated graphic now
          by gshark1
          Hi, I've exhausted lots of software side options to try and fix why my nvidia 2070 GPU has disappeared from my gaming laptop MSI GL75-10SFK. The system boots and functions normally but only using Intel integrated graphics. Before, it was working fine then began having some blue screens. (I will attach the system event and mini-dump at the end of post). After a few days of the occasional BSODs it finally disappeared from device manager and never came back. I researched and attempted to troubleshoot this issue but im out of options and was wondering if yall had some ideas maybe on the hardware side....
          12-29-2023, 04:42 PM
        • coasterghost
          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
          by coasterghost
          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
          System Hardware:
          Processor: AMD Ryzen 7 PRO 5850U
          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
          09-08-2025, 10:46 PM
        • T4-BR
          T470S - TPM issue since TPM/BIOS update from Windows Update
          by T4-BR
          Many thanks for the high quality ressources available on your website.
          I'm currently facing some issues with my T470S:
          - I sat a Supervisor Password using special chars which was causing issues
          - Access to BIOS was locked but I was still able to use my PC
          2 weeks ago, I got an update of BIOS/TPM from Windows Update.
          Computer restarted and after Lenovo logo a loading bar appeared and at the end something went wrong + an error popped.
          Computer restarted one more time and I got the prompt for typing Bitlocker...
          09-26-2024, 02:50 AM
        • Woodsworth
          PS3 CECHC03 60GB YLOD Troubleshooting
          by Woodsworth
          I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
          START
          Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
          03-19-2024, 07:58 AM
        • x16
          Lenovo P50 - nvidia issue - how to reset bios?
          by x16
          My P50 has a faulty nvidia graphics card. It only works with intel. I installed Windows and it works fine withe the intel graphic.
          Then i switched in bios under config->graphics device from "hybrid graphics" to "discrete graphics". Now i have no picture.
          I reset the bios over shorting cmos battery, but still no picture. So i need to change the grapics setting back to hybrid graphics again.
          I need a way to make bios changes over bios dump. Is that possible?
          06-17-2025, 01:44 AM
