Unknown "wanscam" clone IP camera - Power LED lit; no activity
  • fuxxy
    • 318
    This is an unknown IP camera. Most likely a Wanscam clone, PCB has www.wanscam.com silkscreened but board design doesn't match any known boards in the google database.
    Board ID#: AJ118-7A
    CPU: Nuvoton W90N745CDG
    RAM: Winbond W9812G6JH-6
    Flash: Spansion S29GL032N90TF104
    So this camera worked fine until I installed it on the house. Its non-POE, so I ran two cables (ethernet and power) power was terminated on each end with barrel Jack's, positive to center electrode. 200% sure it was wired correctly. Unit was powered with the same 12v 1.5A brick that it was supplied with, and what I used for bench testing/initial setup.
    The only LEDs on this unit are a red and amber on the ethernet jack on the end of the cable.
    Once installed, unit would show the Green LED, but no amber. My POE switch showed 100M HALF DUPLEX. Ethernet cable tested good, I was also able to plug my laptop into the same run and establish a connection.
    I then powered the unit locally with a mains extension cord. This time the green and amber LEDs lit, but did not request an IP from the router. A packet dump of the interface shows ZERO packets being sent from the Camera.
    Removed camera from its installation, tried again on the bench. Both LEDs light, again no ethernet packets sent.
    This unit has an unpopulated serial header. Verified the TX and RX pins on the header are connected to the UART0 pins on the SoC. Connected my TTL<->USB converter to the serial header on the board. Powered unit on. No serial output AT ALL (Tried at 115200 and 9600).
    At this point I'm out of ideas.
    • 31086
    Re: Unknown "wanscam" clone IP camera - Power LED lit; no activity
    check that 1117 voltage regulator - as it's an easy start.
    • fuxxy
      • 318
      Thanks, I'll do that tomorrow after work.
      It appears that the AP2952 SOIC8 buck regulator takes the ~12vDC input power and is configured to output +5vDC. (R47=26.1k & R46=10k).
      I'll test the output pin 3 and see if it is, in fact putting out +5v.
      I'm honestly not sure how the +5v gets to the 1117 on the other side of the board, but I'll trace it out when I get the housing off.
      • CapLeaker
        Leaking Member
        • 8214
        Sounds like something died... just like my function generator that ran for 30mins before it croaked.
        Looking at the regulator, is where to start for sure. Also recheck the UART port whith an oscilloscope to see if the CPU is really doing something or not. You should find one pin where there is some data running.If you power this camera externally you should only need 3 pins on the UART. GND, RXD and TXD. If you get weird letters and things on the screen, it means you got the wrong baud setting. If you get nothing, well either it is dead, or not hooked up correctly.
        • fuxxy
          • 318
          Okay, so:
          The 2952A IC:
          Pin 2 (Input) - 12.23 vDC (same as wallwart output)
          Pin 3 (Output) - 5.18 vDC
          There are two 1117 regulators on this board.
          1117-D33 (TO-252):
          Pin 1 (ADJ/GND) - GND
          Pin 2 (OUT) - 3.27
          Pin 3 (IN) - 5.01
          Tab (OUT) - 3.27
          AMS1117 (SOT-223):
          Pin 1 (GND) - GND
          Pin 2 (vOUT) - 3.28
          Pin 3 (vIN) - 5.01
          Tab (OUT) - 3.28
          I don't have an oscilloscope. I do have a USB-UART board that registers on the computer as a serial port. I've used it in the past to communicate with routers.
          On this board, RX and VCC are clearly marked. Google brings up convincing pinouts for this type of camera. The only thing I'm unclear about is the RX labelling being receive for the camera, or receive for the device attached to the camera - I'm taking a leap that the USBUART TX pin should attach to the camera's RX pin.
          • fuxxy
            • 318
            All the websites I see for 'wanscam serial' reference a baud rate of 115200 8n1.
            When I connect TX>RX on the USBserial converter, I get all kinds of garbage output. Once I connect GND, it stops.
            • CapLeaker
              Leaking Member
              • 8214
              go back where you got the garbage output. When you get that gibberish, play with the baud rate. 115200 8n1 and 9600 8n1 are pretty standard. However, since you are actually getting some crap on the display, means the CPU works. Probably the CPU halts because of a kernel panic, there is a bad block on the S29 flash, or buggy firmware on the flash (reflash it). So maybe reflash and factory reset that thing.
              • fuxxy
                • 318
                I use RealTerm. There is a dropdown with about 10 different baud rates, from 115200 all the way down to 300 baud. Realterm Llows you to switch the baudrate on the fly, easily trying different baudrates.
                None of the baudrates listed in Realterm give me readable output. I'm thinking it's just signal noise that's picked up until I connect GND.
                • CapLeaker
                  Leaking Member
                  • 8214
                  Can you use your TTL on a 2nd camera and see what it does?
                  • fuxxy
                    • 318
                    This is the only camera I have in this model.
                    I did use the same USB/TTL convertor on a ubuiqiti picostation last night to recover firmware at 115200 baud.
                    • fuxxy
                      • 318
                      Decided to revisit the pinout of the UART pin header "J2".
                      I have four pins, but only two of which are labelled:
                      J2-1 is labelled 3.3V
                      J2-2
                      J2-3
                      J2-4 is labelled RX
                      The RX pin is also significant because it's got a square pin pad and the others have circular pads. Is the square pad supposed to be JP2-1, or the pin beside the "J2" silkscreen?
                      This would imply that the two unlabelled pins would be TX and GND
                      When probing the pins with a DMM attached to a known ground plane,
                      J2-1 (3.3V) - 3.27vDC
                      J2-2 (unlabelled) - 0v
                      J2-3 (unlabelled) - 0.41-0.43 vDC (fluctuating)
                      J2-4 (RX) - 3.26 vDC (steady)
                      I think it's odd that the RX would have steady voltage. Does this signify anything to you guys?
                      • CapLeaker
                        Leaking Member
                        • 8214
                        GND is the easiest to find. The 3.3V rail we don't need, since you power this thing externally. RX is marked and the TX is usually next to the RX pin.
                        Basically you should have RX, TX, GND, 3.3V.
                        All you'd need is RX, TX and GND.
                        I was hoping you see valid data on the RX pin, but you reported that you got rubbish at 9600 8,n,1 and @ 115200 8,n,1. No flow control.
                        To me rubbish data means that you need to reset or reflash the firmware / clear the NVRAM (if you could get the UART to work properly). Try setting the com port on the device manager, not only on the serial program.
                        • ngml
                          Repair of an LG split AC system indoor unit PCB
                          by ngml
                          I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                          This indicates an error in the communication between the outdoor and the indoor unit.
                          The outdoor unit is fine, so the problem is the indoor PCB.
                          The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                          I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                          Does anybody have the schematics of this board,...
                          02-01-2025, 12:55 PM
                        • stefanpng
                          HP EliteDesk 800 G1 SFF solder an extra fan header?
                          by stefanpng
                          So the HP EliteDesk 800 G1 SFF has only one fan header on the whole motherboard, a 4 pin cpu. There is a second chassis fan header, but it is not installed, there are just 4 bare through holes and some silkscreen.
                          Other models like the tower version of this computer have the chassis fan header installed, so I was wondering if it was possible to solder in a new 4 pin header.
                          There is some surrounding circuitry, and I think it is identical to this schematic. The CPU fan header circuitry matches exactly except for one filter(?) cap, and the chassis...
                          07-13-2022, 05:54 PM
                        • nobbnobb1
                          Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
                          by nobbnobb1
                          Hi guys,
                          Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
                          When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
                          02-03-2022, 11:14 AM
                        • Raven7032
                          Dell G15 Ryzen Edition (LA-K454P) – No SPI Activity, No Boot, No startup
                          by Raven7032
                          Hello everyone!
                          Stucked with this problem.
                          Model: Dell G15 Ryzen Edition
                          Board: GDL LA-K454P
                          Symptoms:
                          • Board powers on (consumption ~0.5A), but no boot or display.
                          • Fans spin briefly, keyboard backlight turns on, then fans stop.
                          • Can be shut down via power button (EC active).
                          • No POST, no BIOS splash, no backlight.
                          • Led is blinking 2 orange 1 white
                          • No activity on SPI bus (no CS#, no CLK, no MOSI/MISO) even after pressing power.
                          • No APU_PCIE_RST# - 0V
                          Measurements:
                          • All voltage rails present: +1.8V, +0.75V, +3VS, +5VS, VDDCR_VDD, VDDCR_SOC, DDR VDDQ, VTT.
                          • EC_RSMRST#
                          06-26-2025, 11:47 PM
                        • Gjackson
                          Air-conditioning unit power supply failing to power up
                          by Gjackson
                          Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
                          01-08-2022, 09:24 AM
