Multimeter Iso-tech idm 105?
  • bianchi77
    • Jun 2016
    • 1121
    Dear Badcap Members,
    I have Multimeter Iso-tech idm 105, it was working yesterday, I changed the battery,
    but it's not displaying anything know,
    Anyone has the same issue ? What's wrong with it ?
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: Multimeter Iso-tech idm 105?
    bad new battery maybe ?
    • redwire
      • 3907
      I would make sure the battery holder is not corroded, batteries OK not backwards, and power travels through the screw/spacer from the switch PCB to the main board. There's different knock-offs of this model DMM.
      • bianchi77
        • Jun 2016
        • 1121
        battery holder is corroded,
        I put extra solder on battery and now it's working, but let's see if it's stable...
        Thanks for the message
        • retiredcaps
          • Apr 2010
          • 9271
          Clean corrosion. I think you use vinegar and baking soda to neutralise.
          --- begin sig file ---
          --- end sig file ---
          • dj8452000
            How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
            by dj8452000
            I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
            02-18-2025, 08:28 AM
          • trex66
            Craftsman 82345 Multimeter broke!
            by trex66
            My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
            03-04-2025, 04:26 PM
          • max_smart
            T430 laptop doesn't power on- please help me troubleshoot w/multimeter (fixing for fun)
            by max_smart
            First off, this forum really helped me out by advising me to cut some ribbon connectors to the LCD panel in order to fix a 70" TV (lots of threads on Sharp TVs with this issue). I didn't believe that it could work, but it did.
            Now I've been encouraged to try to diagnose something quite a bit more complicated. That is an old T430 motherboard. I work on a college campus so I have access to pretty decent tools. I found the schematic for the motherboard on the site, and have been following traces and taking DC measurements from things. I also don't mind...
            06-01-2024, 03:27 PM
          • JJAAMM
            by JJAAMM
            Problem
            07-06-2023, 06:01 AM
          • antoniu200
            Why does my Uni-T multimeter not measure anything?
            by antoniu200
            Hi! So, a couple of months ago, I got tired of me watching my movies and when someone flips a certain switch in the house, my Blu-Ray to stop working for a second, then come back on (the TV being fine, mind you, connected both at the same outlet). So, I took my multimeter (Uni-T UT33B) and tried to measure the voltage of my outlet when that switch is flipped. Dumb me, I set the multimeter for DC Voltage, while connecting the red cable to the Unfused connection. Of course, both the fuses in the multimeter and in my house blew.
            Now, I replaced the fuse in the multimeter, but it still...
            11-11-2019, 07:40 AM
