Multimeter Iso-tech idm 105?
  • bianchi77
    • Jun 2016
    • 1121
    Dear Badcap Members,
    I have Multimeter Iso-tech idm 105, it was working yesterday, I changed the battery,
    but it's not displaying anything know,
    Anyone has the same issue ? What's wrong with it ?
  • petehall347
    • Jan 2015
    • 4451
    • United Kingdom
    Re: Multimeter Iso-tech idm 105?
    bad new battery maybe ?
    • redwire
      • 3912
      I would make sure the battery holder is not corroded, batteries OK not backwards, and power travels through the screw/spacer from the switch PCB to the main board. There's different knock-offs of this model DMM.
      • bianchi77
        • Jun 2016
        • 1121
        battery holder is corroded,
        I put extra solder on battery and now it's working, but let's see if it's stable...
        Thanks for the message
        • retiredcaps
          • Apr 2010
          • 9271
          Clean corrosion. I think you use vinegar and baking soda to neutralise.
          --- begin sig file ---
          --- end sig file ---
          • dj8452000
            How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
            by dj8452000
            I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
            02-18-2025, 08:28 AM
          • trex66
            Craftsman 82345 Multimeter broke!
            by trex66
            My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
            03-04-2025, 04:26 PM
          • max_smart
            T430 laptop doesn't power on- please help me troubleshoot w/multimeter (fixing for fun)
            by max_smart
            First off, this forum really helped me out by advising me to cut some ribbon connectors to the LCD panel in order to fix a 70" TV (lots of threads on Sharp TVs with this issue). I didn't believe that it could work, but it did.
            Now I've been encouraged to try to diagnose something quite a bit more complicated. That is an old T430 motherboard. I work on a college campus so I have access to pretty decent tools. I found the schematic for the motherboard on the site, and have been following traces and taking DC measurements from things. I also don't mind...
            06-01-2024, 03:27 PM
          • JJAAMM
            by JJAAMM
            Problem
            07-06-2023, 06:01 AM
          • DrDos
            Wierd reading on my multimeter
            by DrDos
            I'm trying to read a capacito 2200uF on my multimeter. It keeps coming up 2,183 am I to assume that means 2 thousand 183? I expected it to be 2183.00? Thanks for the help.
            09-12-2025, 04:44 PM
