Fluke 289 bad supercapacitor replacement repair
Re: Fluke 289 bad supercapacitor replacement repair
Last time I replaced it with an ELNA DSK-3R3H224U-HL. BTW this part number is still current. Mouser and Digikey have them on back order. So it may be good to wait if time is reasonable. It's about 6.8mm in diameter and height is about 2.8mm.
The other one is 10.5mm diameter and is really going to push it diameter wise. One has to be very careful to place the battery so it won't touch anything else. The height is a problem at 8.5mm. That's not going to fit.
Found some EDLC381420-501-2F-70 which could be taped or glued somewhere. These are way more expensive, but in stock for me and still better than shelling out $370 bucks.
Edit: Turns out DSK-3R3H224U-HL is back in stock @ Digikey on July 4th, 2022. Worth while waiting since it is only a couple of weeks until the new shipment arrives.Last edited by CapLeaker; 06-22-2022, 06:15 AM.Comment
but based on your experience it last just 4 years. may be 1 of the reason that voltage is to high for this supercapacitor.
I will buy Panasonic EECS0HD334H 0,33F 5.5V it bigger, but based onother forum it is ok by size.Comment
I have found a simple approach how to calculate the capacitance.
Charge the supercapacitor through a 1kOhm resistor and measure the time in seconds when the U on the supercapacitor is 0.6331 of the load voltage.
Then multiply the number of seconds by 1000 -> mF
Load 3.0V -> 0.6331*3 = 1.8993V
After 255 seconds the U on the supercapacitor has become 1.8993V, so the capacity is about 255*1000=0.255F this is 23% lower than the nominal I bought 0.33F (+-30%)
I looked at those and they aren't available for me. Meanwhile I needed to do up an order and today they pushed the date back 2 months. Hmm... back to square one.Comment
The diameter is close to the maximum possible.
The height is normal and might be even greater.
negative leg has been cut.
But the current consumption has increased in sleep mode from about 10 μA to 60 μA (my another multimeter is not very accurate in this mode).
Also I performed a test before soldering- charge the supercapacitor to 3.0V and keep it for 24 hours, the voltage after that was 2,24V.
I found similar supercapacitor with vertical legs in my stock :-) the voltage after 24 hours was very close to the first oneAttached Filesif you find these attachements useful please consider making a small donation to the site
Yeah... I figured that out too that 10.5mm diameter is the biggest that fits in there.
Panasonic EECS0HD334H has been discontinued long time ago.
I came up with a Eaton KR-5R5H474-R. However the diameter is 11.5mm.
You can squeeze this in too with wires: TDK EDLC371420-501-2F-50
Anyway... I guess I have to wait until the ELNA DSK-3R3H224U-HL are back in stock in September. Ugh!
I replaced that ELNA DSK-3R3H224U-HL with a KEMET FC0V474ZFTBR24 from Mouser. This new cap is much bigger than the old one, but SMD, 3.5V, 0.47F.
The corners on the cap need to be cut and that plastic lid that sits over the board needs to be drilled.
IF you put the unit back together and you can't select anything on DMM and just has a strange behaviour with nothing on the display, the supercap is jammed and shorted out against a different part, guaranteed.
Hence the not getting around the drilling part in my case.
Here is more FLUKE porn for your entertainment.
Did you get the meter to work correctly with the super capacitor or did you have to do something elseI replaced that ELNA DSK-3R3H224U-HL with a KEMET FC0V474ZFTBR24 from Mouser. This new cap is much bigger than the old one, but SMD, 3.5V, 0.47F.
Mine worked fine as kind. However I did read about someone having —— (dashes) in the display. Sure enough if I short the cap out to the nearby SMD pieces and turn it on, I get dashes too in my display. So if someone does get the dashes, recheck the work.
All I did was cut the plastic on the negative side of the supercap to make it fit, take out old supercap, put in new supercap, marked the spot on the cover plastic, drilled a 1/2” hole and screwed the thing back together. Then I verified that all works. The second Fluke 289 got modded exactly the same way and also have success to report. Now we have to wait a few years to see how these new larger supercaps make out over time.Comment
I just got my Fluke 289 come back from warranty service. I initially had the supercapacitor replaced under warranty 5 years ago, and it recently failed again. This time around, they replaced the PCA.
Is there a way to check the board version without disassembling it?Comment
who tested after what minimum voltage on the capacitor Fluke lost date and time settings?
1 year ago I replaced the capacitor and yesterday was surprised that after 6 hours date&time settings was lost. Now I measure the minutes/voltage but I have no idea what is the minimum required voltageComment
quick measurement - voltage of the supercapacitor (Panasonic) in FLUKE 289
HH:MM V
00:00 - 3,223
00:08 - 3,207
00:22 - 3,14
01:00 - 2,973
01:32 - 2,833
02:00 - 2,715
02:31 - 2,593
03:00 - 2,484
03:20 - 2,406
Date &time have been saved after 210 minutes
after about 360-400 minutes Date&time was lost
The minimum required voltage I think in a range 2-2.4 VLast edited by AleXis6; 07-14-2023, 06:19 PM.Comment
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by the_remHello guys,
I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow... -
by ezeniaHello,
Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,... -
by quicknameI'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
I decided to verify that the batteries were... -
by boosti45i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
- Loading...
