Playstation 4, PS4 - Can you ID this Chip/Component/Tranistor connected to Flash Chip
  • reessi
    • Jan 2016
    • 334
    Please see attached aphoto of one from another board I have! It is missing on one board I have and connects to the Write protect pin of the Winbond 25X10CLYA1 Chip.
    According to datasheet write protect pin can be used instead for faster writing.
    What will happpen if left out, can flash become corrupted?
    The writing on chip is M33C8. I tried to look it up on google and some websites with charts, anyone know any good websites?
    Many thanks.
    • 31298
    Re: Playstation 4, PS4 - Can you ID this Chip/Component/Tranistor connected to Flash
    maybe this:
    • reessi
      • Jan 2016
      • 334
      I seams like you are right but how did you find this, I googled for ages. Is there a good website for looking up the codes?
      Also do you know what it is doing with the Flash Chip. I read the datasheet and I understand from that, that it changes output low or high according to voltage change on input. The CD pin or capacitor delay pin is connected to the Flash write protect pin.
      I don't know where the output pin goes!
      I really do not understand what is going on here, can anyone explain please?
      Incidentally the PS4 appears to work without it, including a full install on a new drive and update of firmware!
      Thanks.
        • 31298
        google is NOT fit to use, it returns junk based on marketing revenue and politics.
        • reessi
          • Jan 2016
          • 334
          How did you find out what chip it was then please? Where do you suggest looking?
          Thanks.
            • 31298
            search the forum for smd databook links for a start.
            then use duckduckgo.com and yandex.com
            if it's chinese then use baidu.com
            • reessi
              • Jan 2016
              • 334
              Thanks mate, I will investigate. Have you or anyone else have an understanding of what the chip is doing and why it appears to work with out?
              Cheers.
                • 31298
                if it is a voltage monitor then it's stopping the flash from being written to if the supply is under 3.3v
                so it's to stop the chip getting corrupted by power issues or maybe the lead getting pulled out.
                • reessi
                  • Jan 2016
                  • 334
                  The strange thing is the CD (delay pin) is connected to the flash chip not the output of the voltage detector?
                  Any ideas how this can be working?
                  Cheers.
                    • 31298
                    then maybe it's not that exact chip.
                    • mizuh0
                      MSI B660M Mortar DDR4 (MS-7D42 Rev 1.1) Request for EC flash chip (W25X20CLNIG)
                      by mizuh0
                      Hi all I hope im doing this correctly,
                      I need a firmware dump for the Nuvoton NCT6687D‑M controller (EC flash chip: W25X20CLNIG) used on the MSI B660M Mortar DDR4 (MS‑7D42, revision 1.1).
                      I acquired a ch341a black to reflash my bios, and was so excited to use it that I tested it on the W25X20CLNIG 3.3v chip as I didn't have the 1.8v yet for the bios chip itself.
                      Being a total newbie I straight up corrupted the EC flash chip, and now the power button does nothing, PS_ON# does not change, and when I manually short the PS_ON# pin it immediately turns off...
                      07-23-2025, 03:52 AM
                    • Grouickman
                      Hofmann geodyna 6300 Wheel balancer
                      by Grouickman
                      Hi there,
                      First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
                      Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
                      I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
                      I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
                      03-31-2025, 05:29 AM
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                    • Troystain
                      Help EZP2023+ updated chip database for w25q256jveq?
                      by Troystain
                      Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                      I need to add w25q256jveq chip but I do not know what data should I type.
                      I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                      The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                      11-25-2024, 12:53 AM
                    • ekozeko333
                      [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                      by ekozeko333
                      I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                      🔥 The Problem Started After Suspected ESD/PD Fault
                      I experienced a power issue or ESD event through a USB-C charger
                      After that, the NX20P5090 power switch was visibly burned and was replaced
                      Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                      🧠 What I’ve Done So Far
                      Flashed...
                      06-21-2025, 02:48 AM
