Spektrum DX6E Transmitter Startup loop
  • Jtroutt19
    • Aug 2011
    • 164
    Hey guys so here is an interesting one for ya. Got this RC radio here that will not boot. But acts like it is oscillating if that is the correct term. the lights will come one and then shut off and continute like this until power is removed. It is powered by 4 AA batteries. I will get pictures of the board soon.
  • Jtroutt19
    • Aug 2011
    • 164
    Re: Spektrum DX6E Transmitter Startup loop
    Sorry it took a while to get pictures. I have been off work and the item is at my work.
    • Jtroutt19
      • Aug 2011
      • 164
      So I unplugged all the extra boards and tried to power main board by itself with a desktop power supply. I am still getting the boot loop.
      • Jtroutt19
        • Aug 2011
        • 164
        https://youtu.be/lGVNDXoD3Ag
        A video of the boot loop.
        • rootboy
          • Oct 2017
          • 6
          Have you measured the output of the regulator while it is doing this? Is the voltage remaining constant?
          • Jtroutt19
            • Aug 2011
            • 164
            Yes it is remaining constant. 3.3 volts. I have also used a power supply to supply 3.3v manual to the board and it still does it.
            • rootboy
              • Oct 2017
              • 6
              I did some research, and found that they have a habit of behaving poorly, but nothing on your specific problem (some turning on all by their self, others that won't bind, fast draining batteries, etc). You might have to send it back to Horizon, but their reputation isn't looking too good...
              What I would do next is to disconnect the gray ribbon cable going between the main board and the board that has the X1TXP transmitter module and try that.
              • CapLeaker
                Leaking Member
                • 8352
                Plug in a TTL in that UART and see what she sez.
                • Jtroutt19
                  • Aug 2011
                  • 164
                  Yeah personally I don't use Spektrum I am a FrSky Taranis man. But there are a lot of Bind and Fly models out there that only support Spektrum. So that is why I wanted to see if this could be repaired. I bought this for 5 bucks so sending it back to HH is not viable.
                  I have unplugged all the modules from the main board and it still loops.
                  Can CapLeaker you will have to excuse my ignorance what do you mean by plug a TTL into that UART? I mean I know what a uart and I know what TTL means. Just not sure exactly what you are saying.
                  Sorry for the length of time to answer. Been super busy.
                  • CapLeaker
                    Leaking Member
                    • 8352
                    Right next to the main IC there are like 4 holes in and a square around it. It looks like there is the UART for the IC. Figure out what the RX / TX / GND pins are and wire up your USB or Serial to TTL converter to these pins and let her rip. See what happens on the terminal. Maybe you can put commands in there...
                    • Jtroutt19
                      • Aug 2011
                      • 164
                      OK I see what you are saying now. I will report back
                      • Takeatry
                        Yet another Samsung QLED Boot Loop
                        by Takeatry
                        Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                        10-04-2024, 02:57 PM
                      • blaster_
                        Samsung UE49MU6105K - boot loop, horizontal lines
                        by blaster_
                        Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                        Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                        06-22-2022, 05:19 PM
                      • Stefano Crivellari
                        Lenovo Legion 5 (15ITH6H) kind of boot loop but not sure
                        by Stefano Crivellari
                        Hi, I wonder if anyone can help me fix my Lenovo Legion 5 (15ITH6H) laptop. Basically, after a windows update the computer would not boot anymore. When powering on the laptop the screen has no backlight and nothing would show up, using an external monitor did not help. However, the laptop would still spin up the fans and turn on the keyboard backlight. The keyboard backlight intensity function key would work and the power button led and the charging led are also working. I've tried every possible combination of key press and power button hold down time but did not change anything. At this point...
                        01-14-2025, 03:49 PM
                      • ferah831208
                        HP gaming 15-0013dx quanta G3HA no video, screen polarize on and off loop
                        by ferah831208
                        I have an HP gaming 15-0013dx laptop , motherboard quanta G3HA with AMD Ryzen 5 cpu and Nvidia discrete grsphics card. The laptop turns on and u can see the screen polarizing on and off in a loop but no video signal. All voltages are ok measured and stable (I checked all with oscilloscope). This schematics don't have power sequence but I'm using a similar sequence from another laptop with AMD CPU and I get all to the point CPU must release apu_pwrok and apu_rst#, this signal comes valid only for the period of time the screen is polarized and they disappear and same loop behaviour (active/inactive)....
                        12-07-2024, 04:02 PM
                      • NolesFan
                        Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                        by NolesFan
                        Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                        10-24-2024, 06:36 PM
