Sony PSP 2004 turns on but has no picture
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Good day folks. I hope some of you "console-heads" out there (pun on petrol-head...bad one, I know) can maybe help me with this little project: I managed to score myself a PSP 2004 which has some display issues. Even though I'm not at all what a gamer and would have no real use for this thing, I though I wouldn't just toss it in the trash and try fixing it instead, just for the sake of it and who knows, I might end up selling it or actually getting into games myself...anyway. Here's the problem: the thing turns on, the green light comes on, but there's no picture appearing on screen. SOMETIMES, "Sony entertainment...something" would appear briefly upon startup, but would "dissolve" to black after 1-2 seconds and never come back. Not having opened a PSP before, I followed along with this video, got inside and immediately noticed something was not right: the metal shield that covers the board in the upper-left side looked different on mine than it did in the video and mine was flopping all around the board, since it did not have anything holding onto the board, so my guess is that someone's been inside it before and just threw that shield back on there despite not being the proper place for it...anyway, that was strike 1. Strike 2 was that the flap of the connector that normally presses down over the little flex for the backlight was missing (a common occurrence when someone uses too much force to open up those connectors - those flaps just break off). I tried pressing down on the display connector, but no luck: I still got no picture (not even the dissolving one). I'm getting 5v on the backlight connector and the screen DOES show that brief picture I mentioned, so that part works fine (since many guides talk about a blown backlight fuse, which I'm pretty sure is not the case here). My general knowledge of electronics tells me there's something wrong with either the display itself or a chip somewhere (like a failing GPU on a laptop, since the symptom is nearly identical). Should I try removing the board and blasting it with some hot air and flux ? Not sure which chip to reflow though - there's 2 of them in there towards the left-hand side of the board, where the joystick is. The top one has a heatsink over it. I assume that's the CPU ? Is the one below a graphics chip ? Could that be the issue ? That out of place metal shield is what got me worried, since it could've EASILY moved about and short stuff in there. Any tips would be great. Cheers
    Wattevah...
    • 31293
    Re: Sony PSP 2004 turns on but has no picture
    it's not a soldering issue - those things are solid design.
    probably a bad ribbon connection.
    is it being tested with external power? the battery shouldnt be trusted.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      I had the adapter plugged in...would the lack of power cause such effect despite the console appearing to be on ? That would be friggin' hilarious in fact. I tried messing with the LCD ribbon but I couldn't even get a flash on screen...could be a faulty LCD after all.
      Wattevah...
        • 31293
        if it's been messed with, i would use a magnifying glass first to make sure some fool has not knocked some smd part off the board.
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          Will have to open it up again, as I've put it back together due to lack of space...is there a service manual out there ? Just askin' - haven't done any in-depth research yet.
          Wattevah...
            • 31293
            not sure - try at softpedia.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              Maybe this manual as covers 2000 series
              https://cdn.badcaps-static.com/pdfs/...6cfb4dafd8.pdf
              • CyberPhoenix
                Issue with picture quality of Sony bravia TV
                by CyberPhoenix
                Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                01-22-2024, 02:08 AM
              • noisykid
                Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                by noisykid
                5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                12-30-2024, 07:15 PM
              • iglitare
                Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                by iglitare
                i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                Backlight seems to work, Sound (Setup menu after reset) works.
                If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                With my small knowledge i would think at least the cables are good.
                Can this happen because of a bad tcon board?
                Or is it always a bad/shorted...
                09-04-2025, 07:13 AM
              • tree5656
                diagnosing sony XBR-75X900H. NO PICTURE
                by tree5656
                This tv is not even 3 years old. its a sony XBR-75X900H, it was like a flashbang went off suddenly, tv faded to black and no picture. backlight is on. tried to do the power cycle, factory reset. i get beeps from remote if i tap up/down but no picture. how can i determine if its the panel or a board? i have replaced boards before im just not sure what the issue is here. sony said nothing they can do and only suggested to find a local repair shop. please guide me here
                11-09-2023, 04:55 PM
              • DKWS89
                Sony XBR 49x900E - Sound and backlight on but no picture
                by DKWS89
                Hey Guys,
                So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                12-14-2023, 04:30 PM
