PS4 rejects the cd every minute
  • electronic-solutioncy
    Banned
    • Aug 2016
    • 19
    • 82496679322
    hello i have ps4 which reject the cd every minute i saw many people that say screw the screw of dvd driver which is next to the hard disk but is screw is screw that remove manually the disk and is not screw just turn to eject the cd manually any idea
    • 31199
    Re: Console section
    maybe the eject button is contaminated or damaged.
    • vinceroger69
      • Mar 2012
      • 6714
      Re: PS4 rejects the cd every minute
      Theres loads of posts on google regarding this issue some say it needs the latest firmware update others say try this
      Unplug all the wires from your PS4. This includes HDMI, Ethernet, audio and power.
      Now, count to 10 and then press the power button until the PS4 lights up for just a half a second.
      Yes, this works with the power cord unplugged.
      After this happens, count to 5 and plug the PS4 back in and get back to gaming.
      It doesn’t sound like this will work, but it saved a frustrated call to Sony and got our PS4 back up and running in a few minutes. There is a chance you’ll hear a click and not see a light, but overall this should fix the PS4 constantly ejecting a disk problem.
        • 31199
        so does using the warranty to make the bastards fix it!
        • vinceroger69
          • Mar 2012
          • 6714
          I certainly would make them repair it if i had brought one.
            Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
            The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
            Securing a good thermal interface between...
            10-07-2024, 04:35 AM
          • welp
            PS5 Disk Tray issues.
            by welp
            I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
            Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
            Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
            So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
            With that knowledge I preceded to check all the fuses for the 12v rail on the main...
            12-19-2024, 02:04 PM
          • DynaxSC
            ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
            by DynaxSC
            I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
            Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
            Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
            The behaviour is also really very strange, i.e.:
            • The disk shows always up in BIOS - so it is recognized, so far so good
            • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
            02-23-2025, 01:33 PM
          • hoarderteks_kyriakos
            Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
            by hoarderteks_kyriakos
            Hello.
            Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
            Here is what happened:
            At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
            Today, 07:33 AM
          • chth96
            LG GCC-4521B cannot read any disk
            by chth96
            I bought 6 second hands odd $5 at a flea market and I found that 2 odd(GCC-4521B,TS-H192) won't read any disk.
            But I measured all ESR value of SMD capacitor which is located on the TS-H192's PCB and replaced two capacitor which has higher ESR value.
            And To My joy,this TS-H192 odd finally recognized burned CD as well as pressed CD.😂
            But there was no more good fortune for GCC-4521B..In order to dead GCC-4521B back to life, I replaced three capacitor which has higher ESR value and I rubbed silicon grease on the every glides.I even brushed lens with cotton swab which was soaked...
            02-13-2024, 07:31 AM
