Tektronix 2212 bad 15uF caps
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Gday! I've acquired a Tektronix 2212 with a good EHT and CRT. It had an unstable PSU i tracked down to bad solder on the main trafo last night and after finding that i decided to reflow the solder everywhere along the way checking the caps (out of circuit) and found two 15uF 16v electrolytic caps to be bad on the memory/computer board. could i replace these with film or polymer or should i use Lytics again? Thanks!
    Follow the white rabbit.
    • 31199
    Re: Tektronix 2212 bad 15uF caps
    whatever, its not going to be running 20+ hours a day like a pc or monitor.
    or is it??
    • dragos2009
      • Mar 2013
      • 110
      i would suggest to use polymer if you can find them
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        Thanks STJ, took your advice since they were going to the ground plane anyway i decided to replace them with 22uF.
        decoupling?
        Either way, it's not in the signal path...
        Works great now!!
        It was surprising to find one with a good EHT module and no Horiz. problems for so cheap! The RIFA filter caps on the primary were leaking the famous brown goo though... https://www.badcaps.net/forum/showthread.php?t=32262
        • japlytic
          • Oct 2005
          • 2086
          From what I have seen elsewhere, 15uF 16V seems like low leakage or tantalum units - given the age of the unit, were the defective units in cylindrical cans?
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            Yes. they where Philips electrolytics.
              by momaka
              03-12-2025, 03:42 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
            • Foetuss
              Gigabyte GA-6OXT :: caps question
              by Foetuss
              Good evening
              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
              But I was also suprised about the bigger boys, which are 330µF 25V.
              Could it be they used 25V caps because they were cheaper / available at that time?...
              02-11-2025, 12:22 PM
