Gday! I've acquired a Tektronix 2212 with a good EHT and CRT. It had an unstable PSU i tracked down to bad solder on the main trafo last night and after finding that i decided to reflow the solder everywhere along the way checking the caps (out of circuit) and found two 15uF 16v electrolytic caps to be bad on the memory/computer board. could i replace these with film or polymer or should i use Lytics again? Thanks!
Tektronix 2212 bad 15uF caps
Last edited by goontron; 04-25-2016, 07:25 AM.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Tags: None -
Re: Tektronix 2212 bad 15uF caps
Thanks STJ, took your advice since they were going to the ground plane anyway i decided to replace them with 22uF.
decoupling?
Either way, it's not in the signal path...
Works great now!!
It was surprising to find one with a good EHT module and no Horiz. problems for so cheap! The RIFA filter caps on the primary were leaking the famous brown goo though... https://www.badcaps.net/forum/showthread.php?t=32262Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
From what I have seen elsewhere, 15uF 16V seems like low leakage or tantalum units - given the age of the unit, were the defective units in cylindrical cans?My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
Channel: General Capacitor Questions & Issues
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
- Loading...
