Tektronix 2212 bad 15uF caps
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Gday! I've acquired a Tektronix 2212 with a good EHT and CRT. It had an unstable PSU i tracked down to bad solder on the main trafo last night and after finding that i decided to reflow the solder everywhere along the way checking the caps (out of circuit) and found two 15uF 16v electrolytic caps to be bad on the memory/computer board. could i replace these with film or polymer or should i use Lytics again? Thanks!
    Follow the white rabbit.
    • 30901
    Re: Tektronix 2212 bad 15uF caps
    whatever, its not going to be running 20+ hours a day like a pc or monitor.
    or is it??
    • dragos2009
      • Mar 2013
      • 110
      • Romania
      i would suggest to use polymer if you can find them
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        Thanks STJ, took your advice since they were going to the ground plane anyway i decided to replace them with 22uF.
        decoupling?
        Either way, it's not in the signal path...
        Works great now!!
        It was surprising to find one with a good EHT module and no Horiz. problems for so cheap! The RIFA filter caps on the primary were leaking the famous brown goo though... https://www.badcaps.net/forum/showthread.php?t=32262
        • japlytic
          • Oct 2005
          • 2085
          From what I have seen elsewhere, 15uF 16V seems like low leakage or tantalum units - given the age of the unit, were the defective units in cylindrical cans?
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            Yes. they where Philips electrolytics.
