original xbox power supply
  • smuddge
    • Feb 2012
    • 96
    rev 1.0
    need to know what resistor r10 is on this board if anyone has one.
    i have an original xbox that has a power supply that this resistor has blown right off the board.
    it is in pieces so I cannot read what it was. everything else looks good and the xbox works with another power supply so i know main board etc are good.
    The other power supply isn't the same model as this one and it doesn't have this particular resistor on it.
    any help would be greatly appreciated.
    thanks
  • ohren
    • Mar 2015
    • 121
    • Sweden
    Re: original xbox power supply
    39 ohms 5%
    If your supply is a foxlink ftps-0002 rev b at least. You didn't specify.
    • foxer
      • Feb 2022
      • 15
      • us
      mine is a ftps 0001 rev b and it's 39ohm, too
      R10 is a big resistor btw, what are you doing with your xbox to make that part explode?
      • foxer
        • Feb 2022
        • 15
        • us
        Does anyone here have a list of values for ALL the resistors on the FTPS-0001 rev B? Most of the ones in my psu have either faded color bands or they're browned from heat so I can't confidently tell what values they're supposed to be, knowing them would be helpful if I need to do repairs.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
        • jinu_j
          by jinu_j
          Hi
          05-03-2025, 10:51 PM
        • Andreas_de
          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
          by Andreas_de
          Hello!
          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
          04-12-2025, 10:38 AM
        • shamsudeen
          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
          by shamsudeen
          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
          i know that in linear power supply the noise will be very low comparing to SMPS supply....
          07-19-2025, 07:14 AM
