original xbox power supply
  • smuddge
    • Feb 2012
    • 96
    rev 1.0
    need to know what resistor r10 is on this board if anyone has one.
    i have an original xbox that has a power supply that this resistor has blown right off the board.
    it is in pieces so I cannot read what it was. everything else looks good and the xbox works with another power supply so i know main board etc are good.
    The other power supply isn't the same model as this one and it doesn't have this particular resistor on it.
    any help would be greatly appreciated.
    thanks
  • ohren
    • Mar 2015
    • 119
    • Sweden
    Re: original xbox power supply
    39 ohms 5%
    If your supply is a foxlink ftps-0002 rev b at least. You didn't specify.
    • foxer
      • Feb 2022
      • 15
      • us
      mine is a ftps 0001 rev b and it's 39ohm, too
      R10 is a big resistor btw, what are you doing with your xbox to make that part explode?
      • foxer
        • Feb 2022
        • 15
        • us
        Does anyone here have a list of values for ALL the resistors on the FTPS-0001 rev B? Most of the ones in my psu have either faded color bands or they're browned from heat so I can't confidently tell what values they're supposed to be, knowing them would be helpful if I need to do repairs.
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
        • jinu_j
          by jinu_j
          Hi
          05-03-2025, 10:51 PM
        • Andreas_de
          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
          by Andreas_de
          Hello!
          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
          04-12-2025, 10:38 AM
        • Soulzink
          Samsug washing machine. Power supply DC41-00189a board issue
          by Soulzink
          I am trying to fix a samsung washinmachine power supply main board.
          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
          The power supply board reference is the following: DC41-00189a
          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
          04-19-2025, 06:26 AM
