Garage Door Opener Merlin 5580A
  • dolon
    • Mar 2016
    • 9
    • AUSTRALIA
    Hope its ok to start thread on this topic here.
    We went away on holiday for 2 weeks and not return there is no response when remote button is pressed.
    Attached are photos of the internal guts and the main board and power board.
    There does seem to be any obvious failed components
    I'm wondering where to begin troubleshooting.
    • 31087
    Re: Garage Door Opener Merlin 5580A
    begin with a new battery in the remote - just in case!
    • dolon
      • Mar 2016
      • 9
      • AUSTRALIA
      Yes, already eliminated battery problem as there is no response to wall remote either. Even called Garage Door Service. They wanted to install new system and said the unit has been superseded. It was only installed 8 years ago.
      Anyway went to local hardware depot got and installed a new DIY unit.
      Just want to tinker with this before giving away as its a sturdy unit with metal chain.
      Could only attach 1 photo earlier so photo of boards attached here.
        • 31087
        click "go advanced", then "manage attachments",
        you can up as many foto's as you like.
        • dolon
          • Mar 2016
          • 9
          • AUSTRALIA
          What a surprise! There was one capacitor that had slight bulge on top, so decided to replace it. Only had 1000 mF leftover from previous Samsung repair so put that in and guess what? It worked.
          The opener responds to remotes perfectly! The blue Lelon is the defective cap in the attached photo.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Bad caps in your garage door opener... who would have thunk of that?!
            Good job with the repair! Those folks in the garage door "repair service" have nothing on you, lol .
            • R_J
              • 9556
              I noticed the picture was upside down, but then I noticed your country:
              so now you can take back the new one and get your money back.
              • dolon
                • Mar 2016
                • 9
                • AUSTRALIA
                One could reasonably expect that service technicians would know the common faults and at least do a bit of troubleshooting.
                All the guy did was check power and operate the remote. When there was no response or click it was obviously a receiver/transmitter problem.
                It just seemed ridiculous to scrap a perfectly operating unit just for that.
                  Lift Master garage door opener with WiFi capability application through your phone
                  by sam_sam_sam
                  I had a lot of trouble with the WiFi connection from my router inside of the house into a ( new ) metal garage I had to run a 150 ft cat6 patch cord so the WIFI connection would be strong enough for the WiFi connection on the garage door opener would work correctly ( my son has a work out area in the garage as well and he was having to put his phone near the door to be able to stream music ) ( so I was going to eventually put WiFi out there anyway )
                  This garage door opener WiFi is very touchy if you lose the power it does not remember the password for the router which is weird or...
                  01-21-2023, 08:31 PM
                • Cornboats
                  Garage door opener-safety cutout faulty
                  by Cornboats
                  I have vintage Slavedor garage door opener that has stopped closing the door. If I disable the up/down current control to the motor it works fine. I've attached the larger control board which is for everything and the smaller current control board.
                  Normally the current control is set slightly above the maximum current normally used. If the door exceeds this it should stop and reverse when closing or just stop when opening. Can someone please explain how the current control board works so that I can try and repair or replace the defective parts.
                  I see my self as an interested novice...
                  01-19-2023, 05:25 AM
                  Linear Garage Door Opener Control board took a crap install a new control board back normal
                  by sam_sam_sam
                  I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
                  02-08-2025, 06:52 AM
                • caphair
                  Remote garage door opener - not working
                  by caphair
                  I have two of these and used the working one to do a comparison measurement. Oddly everything seems to be identical in value when measured. I even did a diode mode measurement (+ probe on - battery terminal) of all components and the ic. The values are the same between the two.
                  Only difference I’ve noticed is as follows:
                  Working one:
                  12v on C of NPN transistor
                  Press button
                  0v on both B and E
                  Bad one:
                  12v on C of NPN
                  Press button
                  1.5v on B
                  1.1v on C
                  But the transistor measures good and has same...
                  11-09-2020, 02:57 PM
                • jm1234
                  Garage door module Nice SNA4/A - burnt component
                  by jm1234
                  I'm trying to guess what component got burnt on the control board for my Nice garage door motor Nice SNA4/A. You can see it in front of the 2 capacitors. The component is connected across the 36V rectified input wires, maybe it was some kind of protection device?
                  All the pictures I could find were of the whole product, so enclosed in the plastic box, eg. https://www.ebay.co.uk/itm/123998876212
                  Any help appreciated.
                  06-28-2024, 03:06 AM
