Remote garage door opener - not working
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    Re: Remote garage door opener - not working
    While the meter is too slow to measure the voltage it should still have a little bit of RC filtering and give *some* voltage...
    BTW to take out the effect of the series resistor, what is the voltage at pin 6 of the IC on both the working and nonworking (and might well measure voltages on pin 7). The pin 6 voltage is not RF but should still show something on a slow DMM...
      Lift Master garage door opener with WiFi capability application through your phone
      by sam_sam_sam
      I had a lot of trouble with the WiFi connection from my router inside of the house into a ( new ) metal garage I had to run a 150 ft cat6 patch cord so the WIFI connection would be strong enough for the WiFi connection on the garage door opener would work correctly ( my son has a work out area in the garage as well and he was having to put his phone near the door to be able to stream music ) ( so I was going to eventually put WiFi out there anyway )
      This garage door opener WiFi is very touchy if you lose the power it does not remember the password for the router which is weird or...
      01-21-2023, 08:31 PM
    • CoinCoin88
      Garage door RX unit (Cardin S38C) does not short relay to send opening signal
      by CoinCoin88
      I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
      Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
      09-15-2025, 03:36 AM
    • Cornboats
      Garage door opener-safety cutout faulty
      by Cornboats
      I have vintage Slavedor garage door opener that has stopped closing the door. If I disable the up/down current control to the motor it works fine. I've attached the larger control board which is for everything and the smaller current control board.
      Normally the current control is set slightly above the maximum current normally used. If the door exceeds this it should stop and reverse when closing or just stop when opening. Can someone please explain how the current control board works so that I can try and repair or replace the defective parts.
      I see my self as an interested novice...
      01-19-2023, 05:25 AM
      Linear Garage Door Opener Control board took a crap install a new control board back normal
      by sam_sam_sam
      I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
      02-08-2025, 06:52 AM
    • jm1234
      Garage door module Nice SNA4/A - burnt component
      by jm1234
      I'm trying to guess what component got burnt on the control board for my Nice garage door motor Nice SNA4/A. You can see it in front of the 2 capacitors. The component is connected across the 36V rectified input wires, maybe it was some kind of protection device?
      All the pictures I could find were of the whole product, so enclosed in the plastic box, eg. https://www.ebay.co.uk/itm/123998876212
      Any help appreciated.
      06-28-2024, 03:06 AM
