Using an ATX PSU with an Xbox?
  • pentium
    • Mar 2006
    • 2778
    While I was four wheeling today I found what was left of an Xbox. The motherboard looked okay but the power supply was trashed and I need to see if the motherboard at the least still works.
    All I need to at least see is the front LED to go green and for me to at least get a video signal for now. The power cable that connects the PSU to the motherboard contains mostly 12V, 3.3V, 5V and ground leads as two other wires (PWRGOOD and PWRON). How hard would it be to substitute an ATX power supply for the broken Xbox power supply?
    Would it make things easier if the first test (does the thing even still turn on and output video?) did not require use of the power button?
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: Using an ATX PSU with an Xbox?
    Maybe the psu pinout can be useful: it seems a standard atx psu coupled with a 12 pin connector.
    Zandrax
    Have an happy life.
    • Krankshaft
      • Jan 2007
      • 2328
      While the xbox power supply has standard 12 volt, 5 volt, and 3.3 volt outputs there is where the similarities end.
      The Power On wire signal must be inverted in order for the PC PSU to come on when the xbox sends the power on signal.
      You also need to step down the standby voltage.
      This board does it well:
      http://diy.sickmods.net/Our_Products...nverter/About/
      This is because the stock xbox supply has a 3.3 volt always on standby while a standard ATX PSU has a 5 volt always on standby.
      So in addition to inverting the PSU on voltage you also need to use a voltage regulator for the standby.
      • pentium
        • Mar 2006
        • 2778
        Okay then, I think I can handle the rest.
        Find Nedry!
          by sam_sam_sam
          03-31-2024, 02:12 PM
          Using a 5 volt @ 12 amp switching power supply and two USB doctor volt / amp meter to three IPads on one power supply
          by sam_sam_sam
          I have been wanting to do this project for some time using a Mean-well switching power supply that I bought at least ten of them that were originally in a device that was abandoned for some reason they were listed new but removed from equipment that was never used
          I do not understand Mean-well the capacitor next to the voltage reference ic chip was a brand that is known for failure over time the other capacitors are brand name needless to say it got replaced before I even powered it on for the first time
          I used a four USB outlet and electrical plate that is made for...
          08-03-2024, 07:54 PM
          by sam_sam_sam
          After all of...
          07-13-2024, 08:14 PM
          I am in need of a 21 volt switching power supply with at least 5 amp capacity
          by sam_sam_sam
          I would be open to a 24 volt @ 5 amp switching power supply that can be adjusted down to 21 volts permanently and the over load protection is still functional and low voltage cutoff 15 volt or higher if necessary
          I would rather not have to use a buck converter to get the voltage that I need
          So is anyone else that has successfully modify one for a slight lower voltage had good results willing to share with me the safest way to accomplish this task
          I googled for a 21 volt switching power supply and did not find very much information for switching power supply...
          02-19-2023, 05:47 PM
