Dyson AM01 Fan Cannot Start
  • john_doe
    • Apr 2013
    • 192
    • Malaysia
    I have a Dyson AM01 fan that cannot start.
    The board is covered by some kind of coating which covered the markings on the components.
    I have de-soldered and checked diode D5 and D6 and they are ok. I have also de-soldered 2 small caps of 25v 100uF and they are also ok.
    When the power supply of 240v is plug in, there is 336vDC at the Big Cap but no power at both small caps.
    Where else should I check? I am new to electronics troubleshooting and hope to get help here.
    Thank you.
    John
  • john_doe
    • Apr 2013
    • 192
    • Malaysia
    Re: Dyson AM01 Fan Cannot Start
    There is a component LNK304DN that is connected to the Big Cap.
    Can some expert guide me on how to check this LNK304DN? There is no voltage across the Bypass pin to any of the source pins. Likewise there is no voltage across the Feedback pin to the source pins.
    I really have no idea whether there should be voltages or not across those pins.
    I have uploaded the datasheet for LNK304DN.
    Thank you.
    John
      • 31087
      you have a lot of cracked solder joints on those foto's
      • john_doe
        • Apr 2013
        • 192
        • Malaysia
        Can you point me to those cracked joints?
        Are you referring to the solder joints at the 2 diodes and 2 small caps are horribly done by me?
        Can you guide me on how to check on the LNK304DN component?
        Thank you.
          • 31087
          if you look at the datasheet first page, there is an example schematic.
          if you work out where those parts are on your board, you can meter the output voltage from the cap.
          as far as the cracked joints,
          a crack looks like a fine shadow-ring around the joint.
          once you see one, you will be able to recognise them very fast.
          i marked a few on the big chip, but it may be wise to resolder all of those pins because they are all under the same stress.
          • Longbow
            • Jun 2011
            • 623
            As per your description, your switching power supply is not starting. The primary d.c. voltage on the large capacitor is OK. U1 is the switching controller IC. You can check for various problems by using a multimeter on U1. For example, (power off), the resistance between S and D should be large. If it is Zero, the FET is shorted. You may be able to see a diode (using diode check mode) between BP and S - there you are checking the zener. Sharpen your probe tips so they go through the protective varnish and test the secondary components. I'm betting on a faulty U1. Perhaps the whole schematic is available somewhere?
            Is it plugged in?
            • john_doe
              • Apr 2013
              • 192
              • Malaysia
              Thank you for all your expert advise.
              I will replace the U1.
              Thank you.
              John
              • john_doe
                • Apr 2013
                • 192
                • Malaysia
                Yes, the faulty component is the U1.
                Thank you for all the help given.
                • edmundteosg
                  • Aug 2008
                  I have the same problem, the LNK304 has blown and part of the plastic housing has cracked and dropped off even.
                  • Toueno
                    Dyson Pure Hot+Cool HP00 - Datasheet needed
                    by Toueno
                    My Dyson Pure Hot+Cool, model HP00, no longer starts.
                    After disassembling and accessing the electronic motherboard, I found that the 16A fuse soldered to the motherboard is dead. I decided to do an electronic shunt to see the reaction, and the Dyson turns on for a few seconds and then turns off.
                    It is likely that a voltage control chip or a safety chip is dead, but without the electrical schematics, the repair becomes complicated…
                    Thank you in advance for your help.
                    Best regards
                    08-14-2024, 10:38 AM
                  • chth96
                    desoldered capacitor is self charging until 0.6 voltage.
                    by chth96
                    I have an 21 inch CRT TV which is not able to power on.
                    I disassembled 21 inch CRT TV and measured voltage of main filter capacitor(Samhwa HC 400WV 220uF) in the circuit.
                    It shows 270V on my DMM.
                    So I discharged this main filter capactior completely and detached circuit board from cathode-ray tube.
                    Then I desoldered this main filter capacitor from circuit board.
                    But I noticed that this desoldered large capacitor(Samhwa HC 400WV 220uF) is slowly charged by itself until it reached 0.6V
                    I measured its ESR value with MESR-100 and it shows 0.1 ohm,judging...
                    03-28-2024, 08:56 AM
                  • martonmiklos
                    Dyson DC45 trigger board burnt brush motor driving SO8 IC
                    by martonmiklos
                    Hi fellows,
                    I am trying to repair a Dyson DC45 battery powered hoover.
                    There is a trigger board in it which hosts an Attiny48 and some power stage to drive the brush motor.
                    Unfortunately a SO8 component burned to hell in it together with a 0603 resistor and the IC could not be identified.
                    The Attiny output looks to be survived the problem because when pulling the trigger it outputs high for a while and then turns off.
                    It is likely that it measured the current on the R10 shunt and this is why it is shut down.
                    I have attached...
                    06-29-2024, 12:21 PM
                  • CapThatBrass
                    Why Can I Flash Some BIOS Chips a Clip and Others Desoldered?
                    by CapThatBrass
                    I'm trying to find if there's a logical answer or reason why some BIOS chips can be flashed/programmed whilst still attached to the board (CMOS battery and main battery disconnected) via a clip/pogo probe, and other chips require them to be desoldered and mounted onto some other platform, whether it be a specific PCB or a clamping mechanism. This is regarding laptop and desktop computers.
                    Any explanations would be handy to know.
                    Cheers.
                    10-06-2022, 11:56 AM
                  • VitalComputing
                    Dyson V6 Absolute Not Starting
                    by VitalComputing
                    Hi everybody,
                    I bought one of these and the batteries are a disaster with them. I have a second dud battery now and I'm just about to throw the thing in the bin.
                    The battery is rated 21.6V and supplies up to 16A. I connected two 12V lead acid batteries in series to test the motor - the dyson starts and then stops after two seconds. I'm not sure why, maybe it is the overvoltage protection or maybe the batteries can't supply the required current.
                    I'm just wondering if I put two lead acid car batteries (which would have the required current capacity) in series...
                    07-09-2022, 05:35 AM
