Evaporative cooler controller board problem
  • flinx
    • Aug 2010
    • 132
    I have the controller board from an Evaporative cooler. there is a 5 volt regulator on the board L7805cv. Connected to the Vin pin 1 is a resistor that has blown off it's outer layer and the value is unreadable (it measures 118 ohms). Across ground and pin 3 is a 4.7k resistor.
    I have searched for a schematic for the controller board and of course came up with nothing. Any ideas on how I can guess the value of the bad resistor?
    I'm going to pull the regulator and test it.
    "...off the record, unnamed government sources
    alluded to unsubstantiated innuendos about
    alleged indiscretions and insinuated that they
    are rumored not to be without basis for further
    speculation..."
  • flinx
    • Aug 2010
    • 132
    Re: Evaporative cooler controller board problem
    5 volt regulator shows 4.94 volts with and without a load.
    speculation..."
      Can we see good clear pictures of the board top and bottom sides?
      • flinx
        • Aug 2010
        • 132
        I knew someone was going to ask that. standby
        speculation..."
        • flinx
          • Aug 2010
          • 132
          back side
          https://www.dropbox.com/s/pwjoo5dv67...10601.jpg?dl=0
          front side
          https://www.dropbox.com/s/36b0c6lpib...6_HDR.jpg?dl=0
          best I can do at this time.
          the blue wire on the back is there because part of the trace came of when I removed the regulator.
          speculation..."
            It looks to be a resistor to drop down the Voltage feeding the input of the 5V regulator so the regulator does not to have dissipate too much power due to no heattsink for the regulator.
            What Voltage drop do you get across that input resistor with the load connected so we can calculate how much current is being draw and see if the resistor Wattage is under rated or not.
            • flinx
              • Aug 2010
              • 132
              I cannot answer that since I would have to take it back to my brothers house, go up on the roof, install it in the cooler and power it up.
              If you think it is there to drop the voltage, what would happen if I attached a largeish heat sink and just jumper the resistor?
              speculation..."
                You need to find out what the input Voltage is and the how much current is drawn through the regulator, for example: if the input is 15V, the output is 5V and the current draw is 0.50A, that means the Voltage drops across the Regulator will be 10V, the power dissipation will be 10V x 0.50A = 5Watts of power so you need very good size heatsink, also the output of the transformer will vary with line Voltage so at higher line Voltage the input Voltage feeding the regulator will be higer so even more heat is generated.
                • flinx
                  • Aug 2010
                  • 132
                  ok, well I'll see what I can do. The big problem is that I injured my back a few days ago and would have to have one of my brother go up and re-install it and make a measurement.
                  My other option is that I have a local number to a place that might carry parts for this brand of cooler. I would have to go there on monday and see if I could look at another board (if they have one).
                  A third option is the heat sink. there may be room inside this for one that could be pretty dang big (relatively speaking).
                  The large capacitor on the board is a 2200uf 25v the positive side feeds in to the voltage regulator through the burned resistor, so I would expect the voltage to be less than 25vdc.
                  speculation..."
                  • flinx
                    • Aug 2010
                    • 132
                    ok, well I took a chance. I found a schematic of the control unit (but not the pc board). I gave the board power and checked the voltage going to the burned resistor. I got a reading with the resistor in the circuit of a little more than 22vdc.
                    With the resistor clipped I got a reading of about 23.17vdc.
                    The amp draw was 6.15 milliamps going in to the regulator with the thermostat control panel not attached to the board.
                    The thermostat control panel is at my brothers house. These are 1/4 watt resistors so the amp draw shouldn't be very high.
                    speculation..."
                    • flinx
                      • Aug 2010
                      • 132
                      I did some calculations on possible current draw, and decided to replace the resistor with a 1200 ohm 1 watt resistor.
                      The amperage could be as high as 15 milliamps or as low as 6.15 milliamps leaving the regulator to have to deal with as much as 7 volts (over the 5 needed). Then I added a heat sink I pulled from an old motherboard (used some thermal compound on it).
                      We will see what happens tomorrow.
                      speculation..."
                      • flinx
                        • Aug 2010
                        • 132
                        I had my brother re-install it this morning.
                        The display now powers up, when you tell it to start cooling, it runs through a cycle where it starts the water pumps, says wait on the display, when that goes away you can turn the temperature setting down and the fan motor powers up, then about 1 second later the display goes blank and everything shuts off. If the motor is set for low speed the motor will run for about 3 seconds before everything shuts down.
                        I had my brother check the voltage being supplied to the resistor with the unit on and display working (fan motor off). The voltage is 19.2. I then had him check the voltage across the resistor and that is 13.4, leaving 5.8 for the regulator. With a current draw of about 11 milliamps.
                        Am I right in thinking that I may need to decrease the resistor and allow more voltage for the regulator? Say change out the 1200 ohm for a 560 ohm which would give the regulator about 13 volts to play with, with a current draw of around 11 milliamps a 1 watt resistor would work fine and the heat sink I installed would take care of the rest.
                        EDIT: I checked the specs and the dropout voltage is 2v so I will need to change the resistor.
                        speculation..."
                        • flinx
                          • Aug 2010
                          • 132
                          Changed the resistor to a 470 ohm. Unit now works fine. Nothing is getting hot on the board.
                          For future reference, the control board is from a Phoenix manufacturing or Aerocool EBP-115 evaporative cooler.
                          speculation..."
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            Good job. The original resistor was likely much lower in value, hence why it blew during an overload. You might want to use a 220 ohm 2W resistor, if the pump drops out during undervoltage.
                            If it works, leave it as it is.
                            A working TV? How boring!
                            • Tynan Dill
                              by Tynan Dill
                              Assuming...
                              11-22-2024, 01:46 PM
                              Tankless hot water heater controller board not powering up when power is applied
                              I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
                              I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
                              However I would like to know if I could figure what happened to this controller board if possible
                              Tomorrow I will take some better pictures of both side of both boards
                              The...
                              12-09-2022, 09:14 PM
                            • Grouickman
                              EPILOG Laser - XS002 controller board
                              by Grouickman
                              Hello gus,
                              Just have two XS002 controller board for Epilog laser engraver for repair, looking for any schematic or doc on those board. So far I could only find the "Service training manual", but it's for the whole unit, not specific to the controller board and there is very little info on the board itself.
                              For instance I don't even have the connectors pinout
                              thx.
                              06-10-2025, 11:46 AM
                            • howardc64
                              by howardc64
                              Yesterday, 05:17 PM
                            • WiredRacing
                              Trials and Tribulations with M.NT68676.2 LCD Controller board and LVDS Panel
                              by WiredRacing
                              Hey all, want to poke the hive mind here for a technology I must be missing something critical about I can't discern from looking at spec sheets alone.
                              I have an ATGames Legends Pinball machine, the playfield is a 32" LCD Display. I'm trying to attach an LCD controller to it for direct PC access, as others have been successful.
                              The LCD is a SPLENDID CD320B01A-350 (I think it's a custom panel for ATGames as google turns up nothing), which is mated to a HV320FHB-N02 (47-6021088) T-CON board (this is probably the important component anyhow)
                              The LCD...
                              08-31-2021, 09:42 AM
