i have a original Xbox v 1.6 wit a bad Philips drive, I think. Anyway, the Xbox wouldn't read any DVDs to play games so I bought a new laser. Come to figure out it still will not play any games nor read a DVD with the new laser installed. However, it will play a music cd. I played with the pots on the laser to no avail. So I checked the old laser again in the drive and it does the same thing, no DVDs, but plays music CDs no problem. Any one heard of this problem before? I am kind of stumped.
Original Xbox dvd drive problem
Re: Original Xbox dvd drive problem
Lasers are usually shipped with certain points soldered to prevent static damage during shipping, these need to be unsoldered before the new laser will work
https://www.youtube.com/watch?v=FTYxo3F_YIA
compare the old laser to the new one and look for what looks like a solder blob accros 2 tracesComment
I want it to restore it to original and play games with the kids on it. Never owned an Xbox. Everything else works fine on it, just that damn drive won't read any DVDs nor games. It still plays music CDs, but that's not helping much.Comment
Not sure if this will help, but it seems to pertain to your issue:
http://forums.afterdawn.com/threads/...eaking.495512/
However, if you're not comfortable doing it, modding your Xbox and putting the games in question on a large hard drive with another optical drive might be a preferable alternative. I also wonder if the drive has bad lytics. And the motherboard is version 1.6 as stated in the original post so it should have Nichicon UC rather than the Aerogel Powerstor B series capacitor.Last edited by Wester547; 04-02-2015, 11:34 AM.Comment
what motherboard revision is it btw?
there are 2 safety things you need to do.
1: resolder the power cable connector - it was causng housefires!
2: if it's not a 1.6 then remove the Aerogel capacitor before it leaks so much that it destroys the board.
http://www.eurasia.nu/wiki/index.php/XboxInfoComment
mother board version is 1.6 and it has the Nichicon UC. I read that afterdawn thread before and tweaked like crazy that laser to no avail. I have checked the drive for bad surface mount caps, but couldn't identify any. That doesn't mean they couldn't be still bad. I have toyed with the idea to somehow suspend the drive in such a way, so I could get with my oscilloscope at it. But then I'd be willing just to buy a new DVD drive, if I could find one.
Thanks for throwing ideas at me... keep em coming!
Meanwhile I read that wiki which stj posted.Comment
If I'm not mistaken, some drives have separate optical pickups for reading CDs and DVDs. That might be why the drive will read CDs and nothing else. And here's another tutorial that recommends against treading too far with tweaking the pot:
http://www.xbox-scene.com/articles/philipspot.php
But frankly, those Philips (and Thomson) Xbox drives sound like nightmares. I don't think their optical pickups are any good even from the factory. I've heard and read too many stories about those lasers only wanting to read certain games (DVDs) when they did work at all. The Samsung drives were always regarded as the best because when they worked, they would read anything you'd throw at them. But even then, they had caustic issues (a weak DVD laser optical pickup eventually going bad, the SOH-D16.... the belt getting prematurely worn, etc). So my recommendation would be to replace it with a Samsung Xbox drive (though those Samsung drives are hard to come by these days). If that isn't an option, modding the Xbox might be the last resort.Last edited by Wester547; 04-02-2015, 06:40 PM.Comment
i was using reflashed lg 8164 pc drives with a microcontroller in the back to send the tray signals.
you can run the box wih no drive if you want.
or you can use a pc drive, but they wont play original game disks.Comment
Hmm... yes... that is what I understand now too.If I'm not mistaken, some drives have separate optical pickups for reading CDs and DVDs. That might be why the drive will read CDs and nothing else. And here's another tutorial that recommends against treading too far with tweaking the pot:
I personally don't care what for a drive is in it. Even if I have to put a small daughter board in there or flash it some how in order to read original game discs, as long as everything fits inside and it works like original. I just have to figure out what needs to be done to get there. Makes my kiddies happy!
cheapest you can get,
as long as it's flashable.
because in the end it's just a replacement bios - and i have the tools to customise it.
http://www.eurasia.nu/modules.php?na...ox_M8plus_BIOS
http://www.eurasia.nu/modules.php?na...e=EVtool_1.0.9
http://www.eurasia.nu/shop/product_i...roducts_id=266Comment
by bulkchart32i ordered a lot of caps from digikey to repair my xboxs. one thing i ordered was 50NXA10MEFC5X11-ND caps and i think they are not polarized. will this cause any kind of a problem? i really don't want to order new caps just because of this.
by tccyo22Hi there, I have an Xbox One original in which I have all the 1.8v, 3.3v and 5.0v standby power rails present, however my 12v rail is not turning on and the enable signal PSU_V12P0_EN from the SMC to turn the power supply on is missing. There is high resistance on this line so it's not shorted directly to ground which leaves me with not many options.
Was looking at a schematic and see the enable is created by the SMC. I have 3.3v on SMC_RST_N_IN but I'm a little stuck on where to look next. Is it likely that the SMC has gone bad or am I missing something else (it's my first time with... -
by bulkchart32nichiconare what i used because i had heard the voltage doesn't matter as long as it is more than the original cap. i'm now reading that high voltage may make the cap's esr too high. is this a good cap for replacing those oem ones?
1500 µF 16 V Aluminum - Polymer Capacitors Radial, Can 8mOhm 2000 Hrs @ 105°C -
by theone111I have an LG Plasma TV 60PM6700 for the past ~12 years.
In the last ~3-4 months I have been having some issues.- Problem: It started with random picture disappearing (sound still worked).
Solution: Had to turn off TV wait a few seconds before turning it on again. - Problem: Then it got worse and the TV started to shut down and when turning on the no picture just sound.
Solution: Had to turn off TV wait about 10-20 seconds and turn it on again to solve. - Problem: TV shuts down
1 Photo - Problem: It started with random picture disappearing (sound still worked).
by NatoPotatoHey there friends!
I have an original Xbox power supply, model FTPS-0002, that isn't showing any signs of life. I have never really done power supply repairs before but I'm eager to learn so I am hoping someone can help me diagnose this.
The issue is that I get no 3.3VSR standby voltage which in turn leads to no 5v or 12v. A couple things I have noticed in my initial inspection.
Resistor 25 and 29 are both reading OL, Capacitor 17 and 20 seem to be leaking as seen in the photos.
So far I have confirmed that 240v, main fuse and the 400v cap is... - Loading...
