PS3 FAT NEC/TOKIN Resistance Testing, need help interpreting values
  • jkucukov
    • Feb 2025
    • 29
    I'm in process of diagnosing the yellow light of death symptom on my PS3 FAT console CECHG01, in process of getting the Arduino gadget to be able to access Syscon and be able to read fault codes. In the meantime, I'm trying to measure resistance of the NEC/Tokins while still attached to the board. I took the Ohm readings from each of the NEC/Tokins from front and back of the board (4 from the RSX and 4 from the CPU chips).
    What I gathered in the attached pictures are values from the CPU NEC/Tokins are consistently measuring 1.6 Ohms while on the RSX they measure 3.4 Ohms except for two places where its open circuit (OL) no measurements. I understand that these are like capacitors and are hard to measure on the board. I hope somebody more experienced can tell me if what I'm seeing is a set of bad NEC/Tokins on the front side of the board or a bad RSX chip?
    Click image for larger version  Name:	20251003_144158.jpg Views:	0 Size:	442.1 KB ID:	3738429 Click image for larger version  Name:	20251003_144231.jpg Views:	0 Size:	588.3 KB ID:	3738430
    • 31188
    • jkucukov
      • Feb 2025
      • 29
      Originally posted by stj
      Thank you for sharing, the values I was able to pull from looking at the shared diagram is as follows:
      RSX_VDDIO = 85.2 Ohms
      RSX_PLL = 5.78 kOhms
      RSX_VDDC = 4.1 Ohms
      Keeping my fingers crossed 😊
        • 31188
        values will be different for a "G" board because they use 65nm chips instead of 90nm
        • cind12
          GTX 1080 TI Gigabyte Aorus low resistance on vmem
          by cind12
          Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
          Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
          The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
          Resistance on 12V 4K ohms (Power present when on)
          Resistance on 12V PEX 4K ohms...
          12-08-2023, 09:09 AM
        • sony855
          about resistance help 2 inductors that have different values
          by sony855
          Hello !
          I would like to ask you . How I can learn the exact resistance value of each component. Im talking about laptop motherboard. I have 2 inductors that have different values one is 0.200k om other one is 0.100 kom . Thanks . How to know which value is good and which one is not goof. Thanks
          02-05-2024, 03:03 PM
        • proxneo
          Recapping Sony ICF-SW55 - verifying cap values
          by proxneo
          Dear reader
          I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
          At the moment, I have selected replacements based on the following list of values:
          3 x 470uF 10VDC
          3 x 4.7uF 35VDC
          4 x 47uF 50VDC
          8 x 22uF 6.3 VDC
          1 x 220uF 6.3VDC
          5 x 100uF 6.3VDC
          Which...
          06-21-2023, 12:38 AM
        • rashidjafar
          Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
          by rashidjafar
          I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
          Values for :-
          PC43 : Capacitor [3x1.5mm]
          PL7 : Inductor [2x1mm]
          PC39 : Capacitor [1x0.5mm]
          Any ideas would be appreciated.
          I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
          08-07-2025, 05:10 PM
        • Kobok
          Different (lower) resistor values on PCB?
          by Kobok
          Dear Alls,
          For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
          09-19-2022, 07:30 AM
