guys..i need help with this lcd display used on ebikes pls.
  • vikivng
    • Feb 2019
    • 228
    This is an lcd display used on ebikes.
    long story short, there was condensation inside the unit.
    I opened it and thoroughly cleaned the pcb with isopryl.
    The board had no visible corosion.
    It powered on fine and was tested for an hour or so.
    However when connected to the bike,,it did not power on at all.
    I took it home and reopened it to take a look. There are no shorts based on MY testing.
    However,,when I probe the transistor and the mosfet gate in diode mode or contuinity mode, (one probe on transistor collector and one probe on mosfet gate}the unit powers up.
    Aslo with one probe still on collector and the other probe on any of the 2 resistors close to the mosfet ,,the unti powers up.
    If an NPN transistor in installed instead of the PNP, THE UNIT COMES ON AS SOON AS POWER IS APPLIED. However , it can be turned off with the power button in this state but will not turn back on with the power button.I dont know what to do next to fix this..pls help
    The large mosfet and the transistor are picture at the edge of the board.
    I believe htis circuit is the emitter follower circuit.
    I am getting full battery voltage at the gate of the mosfet, 40v at the emitter and 39v at the base.
    I dont understand why the transistor never turns on the mosfet.
  • Jane
    How do you test MOSFET in laptops ?
    by Jane
    I tried to use this method:
    Testing an N-channel MOSFET:
    Step 1: Discharge the Gate (turn off the MOSFET)
    Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
    Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
    Step 2: Charge the Gate (turn on the MOSFET)
    Now, place the red probe on the Gate (G) and the black probe on the
    09-27-2024, 03:31 AM
  • littlejohn
    mosfet or transistor ?
    by littlejohn
    I'm working on a LED circuit board and am testing a 8C 1A component, it has a wide ground tab on one side and 3 tabs on the other and the center tab is grounded also. the circuit board has it as a V2 component ,so is this a mosfet or transistor ?
    08-03-2025, 10:32 AM
  • Nooy
    VGA MOSfet permanently shorted and loss of MOSfet pad
    by Nooy
    Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
    I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
    02-14-2024, 02:26 AM
  • Tomylee
    HP 15-fc0007ca Charger Cycling On/Off with Hot MOSFET – Need Component Info
    by Tomylee
    I have an HP 15-fc0007ca that works normally, but when I plug in the charger while the laptop is powered on, the charging cycles on and off repeatedly—it starts charging, stops, then starts again.
    Using a thermal camera, I identified a MOSFET that is overheating, along with a small 2R2 resistor next to it that gets even hotter than the MOSFET.
    I also hear a “zpzpzpzp” type noise, but the noise is not coming from the same area as the hot MOSFET. I will include a photo with the exact spot where the noise is coming from highlighted.
    11-26-2025, 12:24 PM
  • redbaron1007
    Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
    by redbaron1007
    I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
    Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
    09-09-2025, 11:10 AM
