PS4 NOR check error su-37553-3
  • SoJustMe
    • Jul 2024
    • 5
    • Saudi Arabia
    Hey guys,
    Need help checking the ps4 nor dump
    Ps4 system does not update
    Error Su-37553-3
    I already tried everything but nothing work the only thing left is NOR flash might be corrupted
    Can anyone fix it if its currupted please!!
    • Also i dumped another console same model and board that it work but don't know if i flash it will be ok? Afraid to mess thing up not used to do software things
  • Ipvano
    • Nov 2023
    • Германия
    Hi, try this dump and use new SPI Flash.
    • SoJustMe
      • Jul 2024
      • 5
      • Saudi Arabia
      Many thanks, i flash it and it worked like a charm.
      Finally the system update with no error.. i tried evertything but nothing worked only left me in puzzle and lead me only think that NOR is corrupted and was my conclusion right..
      How did you repair it ? The other guy was giving me links for paid tools i doupts...anyway if you can tell me for my curiosity i will be thankful.. and i have a dump from a working one , what if i flash it will it work or not? Because i did not have the courage to do so lol i was afraid to brick it
      • Superbee_dad
        Sharp 80” long short flash backlight error - Help
        by Superbee_dad
        Hello Sharp TV experts
        Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
        > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
        > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
        01-24-2025, 11:51 PM
      • Sus256
        HISENSE 65E7KQ PRO - no boot
        by Sus256
        Hi all!
        HISENSE 65E7KQ PRO
        RSAG7.820.13512 - chassis
        MT9618BAATAB - cpu
        RSAG7.820.12059 - power
        HD650Y3U77 - panel
        KLM8G1GETF - emmc
        Replaced emmc.
        Terminal log
        UART
        AC_ON
        E-B
        FDE enabled
        06-01-2025, 02:11 AM
      • kyrios
        Flash LG PK5 DEMO - CH431A ERROR - verification error on address 00000000
        by kyrios
        Hello!
        I apoligize for my English. I need some help.
        I have an LG PK5 in demo version and trying to repair it, I found the original firmware in this forum to flash speaker to the original version.
        Without having any idea about these things, I give thanks this forum and other tutorials, I bought a CH431A programmer and I have tried to do all the steps but after reading the new firmware, in the "verification" step I get this error: verification error on address 00000000
        Could someone help me to solve it, please?
        Thank you so much
        11-30-2023, 01:06 PM
      • sushilachuthan
        APC UPS error P13
        by sushilachuthan
        one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
        the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
        The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
        We replaced the SCR with new device,, but the device is not power on as expected.
        Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
        09-26-2025, 09:00 AM
      • ekozeko333
        by ekozeko333
        🧠 What I’ve Done So Far
        Flashed...
        06-21-2025, 02:48 AM
